stulad
| posted on 13/8/06 at 07:16 PM |
brake reservoir
any help please my brakes hang from abouve so the cylinders are higher than the front of the car , im looking at mounting reservoir at the back of the
car and running long pipes , see attached pic , can anyone else see a prob with this will i end up with air locks ??? going up and down, there is
veryy little room under the dash , could have integral reservois if so are these sva compliant ??
many thanks see attached pic cheers stu
.jpg)
RazMan
| posted on 13/8/06 at 07:23 PM |
Stu, I had a look around and came up with these ...
.... which might be a better idea than mounting the reservoirs such a long distance away from the master cylinders.
You would obviosly have to devise some kind of level switch in the reservoir but a man of your talents etc ....
[Edited on 13-8-06 by RazMan]
Raz
stulad
| posted on 13/8/06 at 07:38 PM |
damn your fast
Cheers Raz.
met up with ur mate today, very nice guy.
thanks for the reply in super fast time.
you need to pop round again as i need help with this big style.
i will need to use 2 of them just for brakes, also they are under dash as you know , have put dash in place and it will need to be removable or a hole
cut in as Andy suggested, going to leave pedals alone and cut panel out for throttle hhahah my life just gets better and better
many thanks , p.s were do i get them from and why 2 filler caps ??
cheers stu
stulad
| posted on 13/8/06 at 07:42 PM |
raly design
im guessing rally design
(wilwood) i think maybe i need to take a drive there and talk to the guys about my probs
lsdweb
| posted on 13/8/06 at 07:45 PM |
Stu
If you have a balance bar pedal box and need two master cylinders, these are probably your best option:
http://www.hispecmotorsport.co.uk/master_cylinders.htm
Regards
Wyn
RazMan
| posted on 13/8/06 at 07:48 PM |
Yep, they should be able to help get hold of whatever Wilwood parts you need.
The two caps are for separate (dual circuit) brakes but I think you can have a single res option iirc which might simplify the level switch - maybe
mounted in the cap.
A service panel would be ideal under the front section somewhere which might also help in getting to the loom if need be.
*edit* I forgot about the balance bar! You might be better off having a bias valve instead - this might be simpler but then again ....
Raz
stulad
| posted on 13/8/06 at 08:12 PM |
quote: Originally posted by lsdweb
Stu
Regards
Wyn
will i be able to add a level indicator to these ?Girling Integral Reservoir
Master Cylinder
0.75"
cheers stu
stulad
| posted on 13/8/06 at 08:14 PM |
lol Raz
Raz will call you to discuss , hope you know what your talking about
stu
DIY Si
| posted on 13/8/06 at 08:16 PM |
Is there not some spare corner in the front for a pair of small reserviors? They don't take up much space. Half a shoe box size space would be
more than enough. They could even be placed seperately if need be.
Sun Tzu, The Art of War
lsdweb
| posted on 13/8/06 at 08:34 PM |
Hi Stu
You can get a top with the required electric level warning light bit - a quick wander around the scrappies will sort you out.
If you're desperate, I've got a pair somewhere which I used when I SVA'd my Fury. I was going to hang on to these just in case I go
through SVA again sometime but you're more than welcome to borrow them.
Regards
Wyn
gttman
| posted on 13/8/06 at 09:02 PM |
The problem Stu has is that the master cylinders are higher than all of the front end as they are top pivoted pedals & thus the cylinders are
steering wheel height.
Andygtt
Please redefine your limits
DIY Si
| posted on 13/8/06 at 09:04 PM |
Ah, I see.
stulad
| posted on 13/8/06 at 09:10 PM |
GTTMan has it spot on.
i moked dash up and there is very little room under it so lets say i cant get reservoirs under dash is an up down pipe going to be a problem ??
cheers
DIY Si
| posted on 13/8/06 at 09:18 PM |
As long as you can remove all the air from the pipe it shouldn't matter where you put them.
stulad
| posted on 13/8/06 at 09:24 PM |
i was told by a kit car builder http://www.klimcke-racing.com/
that the reservoires had to always be higher than the cylinders , but the car designer \John said that they didnt he suggested just lifting them when
i bleed the system. so no i dont know , i would rather not do long feeds to the rear but at the front will be lower than the cylinders.
in saying that if you pressure bleed the pipes and loose all the air as long as it never runs dry theer is no reason air or gravity should get
involved .
just dont know what sva requirements are .
cheers stu
gttman
| posted on 14/8/06 at 11:39 AM |
I've thought some more since we spoke and I'm sure the master cylinders are gravity fed from the resovior so is there not a risk that
fluid will brain out of the master back into it if it is low in the front......... I think the only options are under the dash like I am doing or in
the rear is allowable.
BTW did you know that Wilwood also do some very similar pedal with the masters behind the pedals and thus quite a few inches lower?
http://www.wilwood.com/Products/005-PedalAssemblies/002-FSMP/dual/index.asp
Andygtt
stulad
| posted on 14/8/06 at 12:51 PM |
Mhh Thanks Andy , I have spoken to Rally Design who have confirmed that the reservoir must be very slightly higher than the cylinders, even a none
return halve wont help.
they also have said that a long run to reservoir is pants also because of delay and back feeding.
soooooooo i will have to find some space under the dash.
Many thanks for everybodys help , will use this cylinder with combination installation possibilities
http://www.wilwood.com/Products/006-MasterCylinders/002-CRMC/index.asp
