Author: Subject: Caterham Superlight weight - K series - similar to Zetec?
Just
posted on 26/8/06 at 03:37 PM Reply With Quote
Just been driven on a track in a Caterham 1.8 superlightweight with a 160-170bhp K series in it. It made my Pinto look sloooow and was wondering if that particular engine was something really special or if an upgrade to a 1.8 Zetec with TBs would have the same results for my Tiger?
Jubal
posted on 26/8/06 at 03:47 PM Reply With Quote
They weigh around 500kg, model dependent. So the one you were in had about 320bhp per ton. None too shabby.
There was an R300 at the last trackday I did. 160hp and 525kg. It was usefully quicker than my blade Indy. You can't argue with physics.
Hammerhead
posted on 26/8/06 at 04:11 PM Reply With Quote
zetec engines weigh more than K series as far as I am aware. The K is all ally.
Danozeman
posted on 26/8/06 at 04:26 PM Reply With Quote
The k series is a very quick revvy light engine. I contemplated one for mine at one point.
Different management and TB's they are very quick..
Dan
ady8077
posted on 26/8/06 at 04:36 PM Reply With Quote
Hi
The zetec SE weighs about the same as a K and has the exhaust on the same side as a pinto, there only a 1.6 but shawspeed recon they can be tuned to over 200 bhp
Might be an easier swap?
Adrian
ned
posted on 26/8/06 at 05:51 PM Reply With Quote
friend of mine is building an indy with a zetec se, apart from the bellhousing you can use it pretty much standard as the injection manifold sits under the bonnet nicely and its all ally and a suprisingly small/narrow engine compared with most 2ltrs so easier to work around.
1.7 variant in puma's and they can be upgraded relatively cheaply for good power.
Ned.
beware, I've got yellow skin
skydivepaul
posted on 26/8/06 at 10:17 PM Reply With Quote
i looked into this recently as a change from the BEC. puma 1.7 or new fiesta 1.6 zetec SE can give 200bhp.
expect to shell out over £3000.00 not including the engine to get this sort of power and you wont have anything under 2000rpm. brilliant for sprints, hillclimbs, track and race but might be a flat on the road. like a BEC
also what you are trying to compare is a very expensive well sorted car with a budget blaster. nothing wrong with the MK or locost types but the caterham R300 is a very quick car....................you get what you pay for
[Edited on 26/8/06 by skydivepaul]
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
