Author: Subject: paddle shift
ruskino80
posted on 28/8/06 at 08:27 AM Reply With Quote
paddle shift
paddle shift complete and working-system from pathfinder ,works a treat and excellent service from thom.note cable rather than rods. Rescued attachment r1 paddles.jpg
StevieB
posted on 28/8/06 at 09:14 AM Reply With Quote
That looks really good!
I'm going for a paddle shift from MK on my own car - was it easy to fit?
ruskino80
posted on 28/8/06 at 09:35 AM Reply With Quote
does give issues with clearance on steering wheel-and had to have back of paddles strenghthened to eliminate flex.but otherwise its simple enough.
StevieB
posted on 28/8/06 at 09:42 AM Reply With Quote
I can see it's a bit tight for space behind the wheel.
I was planning to have the paddle shifts, with the R1 switchgear mounted behind the wheel and the R1 clocks on the dash behind the wheel too - that way I only need a small dash binnacle and just need to put a bit of edging trim around the rest of the scuttle (I'm afraid I'm from the 'if it doesn't do something essential, it's just extra weight' school of thought!)
Looks like I might have to have a bit of a rethink though!
ruskino80
posted on 28/8/06 at 09:48 AM Reply With Quote
mounting the clocks behind the wheel i am sure would hamper your vision of it mainly the neutral light which you do need to see.also the switch gear in this area would be to crowded and i dont think you would be able to operate the switches well.
StevieB
posted on 28/8/06 at 10:18 AM Reply With Quote
Just had a look around some photo's on the site and can see what you mean.
Back to the ideas board then - there must be a way...
OX
posted on 28/8/06 at 10:51 AM Reply With Quote
on my r1 i put the clock behind the steering wheel just on top of the paddle shift and the switches on the centre panel but tha dash looked silly with nothing on it.
StevieB
posted on 28/8/06 at 10:56 AM Reply With Quote
The plan was not to have a dash at all, but just a piece of carbon just big enough for the clocks and switches. It's all part of a 'less is more' theme.
alfasudsprint
posted on 29/8/06 at 07:10 PM Reply With Quote
Got a link or tel no for pathfinder? how much?
thanks
Crazy Jay
posted on 29/8/06 at 08:17 PM Reply With Quote
Click here
This should help
alfasudsprint
posted on 19/9/06 at 09:21 PM Reply With Quote
Ruskin
Ruskin,
where did you get cable for gear change from? is it push/pull type or two pull/pulls?
tim
