pathfinder
posted on 6/9/06 at 03:48 PM |
inlet manifolds anyone?!?
Hi Gents
Would there be any demand for inlet manifolds if I got a few cut?
I have had a couple of enquiries recently but to make it cost affective I need to cut a batch.
To start with I was going to do a copy of the carb’d Pinto inlet manifold gasket in 4mm Stainless either sold as blanks or with inlet tubes tig’d on
to accept bike carbs or Webbers!
I’m just thinking out loud at the moment but u2u or post on this thread if you think it’s a goer or think there is another manifold which is
required.
Regards
Thom
[Edited on 6/9/06 by pathfinder]
westf27
posted on 6/9/06 at 03:58 PM |
Well i need a pinto one for kawasaki carbs
555
posted on 6/9/06 at 05:29 PM |
Depends on price I suspect! I'd like a 20XE inlet manifold flange if it was cheap enough. Hacking away at a bit of 10mm plate for hours on end
doesn't fill me with glee...
theconrodkid
posted on 6/9/06 at 07:51 PM |
how bout some zetec exhaust mani plates?
who cares who wins
pass the pork pies
matt_claydon
posted on 6/9/06 at 08:33 PM |
I'd probably be up for a zetec one as I'll be going zetec at some point in the future. Problem is going from the oval ports to round tube
needed for bike TBs / carbs.
Also, working from an inlet gasket is a bad move as they're usually pretty innaccurate with oversize holes. Ideally you would take accurate
measurements direct from a head.
GlynC
posted on 6/9/06 at 09:42 PM |
been trying to get one for a Pinto to my Suzuki Throttle bodies for ages
Have a big box full of bits just waiting for fitting then!!!
Do you have an idea of cost?
Crazy Jay
posted on 6/9/06 at 11:02 PM |
Hey, a mate of mine is fitting gsxr tb's to his E30 318is. If he was to send you the inlet manifold would you be able to make the new one up? I
realise this wud be a one off so more expensive, its just he cant find anyone to make one up. Cheers
Dusty
posted on 6/9/06 at 11:33 PM |
4mm might be a bit thin. I think 8 is better. At Newark I noticed that custom chrome were doing manifold plates for pinto and a few others for £10
each. Might be a good starting point.
