Lennart
posted on 10/9/06 at 12:05 AM |
Support steering colum
Because of the exhaust I've got an extra UJ in the steering colum.
But how do I make a support to hold the colum?
Do I have the colum 'rolling' in rubber of can I have an aluminium bracket with a steering colum?
Any ideas? Photos?
Many thanks, Lennart.
theconrodkid
posted on 10/9/06 at 06:54 AM |
i used a rose joint,measure your shaft and get a joint with the right sized hole
who cares who wins
pass the pork pies
RichardK
posted on 10/9/06 at 08:14 AM |
I used a rose joint, more pictures in my gallery by clicking the www button below. main picture here.
Regards
Rich
BTW it does have locking nuts on now!
Lennart
posted on 10/9/06 at 08:16 PM |
Thanks for the solution about the rose joints!
I've got a standard Dax steering colum extention of 15mm (5/8".
On the Burton Power site there are quite some 5/8" rose joints, but which one should I need?
https://www.burtonpower.com/dets_product.aspx?PGrp=21015&PSet=98
Lennart
posted on 13/9/06 at 09:22 PM |
Maybe not really clear to all. What I did mean was, what's the difference between underneath rose joints and which one should I use for
supporting the colum?
Burton Power doesn't answer my e-mail.
SPHERICAL ROD END 1/2x5/8 RH CARBORACE
SPHERICAL ROD END 1/2x5/8 LH CARBORACE
SPHERICAL ROD END 5/8x5/8 RH CARBORACE
SPHERICAL ROD END 5/8x5/8 LH CARBORACE
SPHERICAL ROD END 5/8x3/4 RH CARBORACE
SPHERICAL ROD END 5/8x3/4 LH CARBORACE
SPHERICAL ROD END 1/2x5/8" R/H 31390LBS
SPHERICAL ROD END 5/8x5/8" L/H 17955LBS
SPHERICAL ROD END 1/2x5/8" L/H 31390LBS
Can anyone give me an understanding answer about the rose joints? What is a rose joint btw?
Ta, Lennart.
posted on 13/9/06 at 11:29 PM |
Rose joint is a brand name.
It is now a generic term for spherical rod ends. You don't need an expensive race item for your column bearing. The cheap 5/8"x5/8"
right hand thread would do the job. You can get them a lot cheaper from Nick Skidmore on here if he has any or a local bearing supplier would carry
them.
