Lawnmower
posted on 18/9/06 at 12:26 PM |
Would you buy a high mileage car?
I am looking to buy a landrover.
I can get a 1995 300tdi for £1900, but it has 200,000 miles on clock! its for swmbo to travel 45miles a day in, plus weekend toy.
Would you buy it?
posted on 18/9/06 at 12:31 PM |
I guess it depends on service history to a large extent. At 200k virtualy everything suspension/steering wise is going to be getting a bit tired,
what has been replaced? Likewise if it's the original turbo then surely it's living on borrowed time?
graememk
posted on 18/9/06 at 12:39 PM |
200K, no just to many miles, i dont think it would make a reliable car
bimbleuk
posted on 18/9/06 at 01:00 PM |
I bought my Audi A4 Tdi with 130K on the clock. I've done 30K miles since with no major issues. I have replaced a couple of the suspension
bushes on the front suspension. The clutch is just starting to show signs of wearing out. However its only £80 for a new one and I'll fit it
myself. The car came with full Audi servicing from new which helped make the buying choice.
Agriv8
posted on 18/9/06 at 01:07 PM |
I Bought my passat TDI at 130,000 now done 195,000 miles. Ussual suspension bushess.
original clutch lasted to 170,000 CV joints 180,000.
I would trust VAG group to this milage not sure about solihulls finest though.
regards
Agriv8
posted on 18/9/06 at 01:09 PM |
Depends!
Are you happy to spend the time and money required to keep it on the road?
I usually take the view that paying more up front for a vehicle means less time and money spent keeping it on the road.
I'm guessing it has to be a Landy for emotional attachement reasons? Does this rule out other vehicles? £1900 could get a tidy small car with
a lot less miles on the clock - Pug 306 etc!
mcerd1
posted on 18/9/06 at 01:13 PM |
Firstly landrovers, transit and other decent vans - infact most commecial vehicles need a different set of rules when it comes to high mileage
60k on a car and you'll expect it to start getting a little worn and taty
120k on a car and you'd expect it to be on its way to the scrap yard (assuming it 8-12 years old)
100k on a landrover and it will be starting to need things looked at (providing its been looked after up to that point)
is it a 90/110 or Disco ???
Have most of those miles been on-road or off-road ??? (salt and sand are the real killers)
200k Disco bodywork will probibly have a fair bit of rot - not too much you can do about that
200k 90/110 will need some bodywork done (but this is almost just a case of swaping panels and paint like the S1, 2 & 3's) make sure the
bulkhead is ok though - new panels arn't cheep, but you should be able to find second hand ones
Running gear on a 100k landrover will be starting to get a bit tired (depending on how its been looked after or not) by 200k you'd hope it has
had most things replaced or serviced at least once
the chassis could be completly rotten, check it carefuly (with a hammer) look for signs of repair welding
gearbox will probibly need rebuilt if it hasn't been done
300 tdi's are ok but 200tdi's are simpler and stronger (but also older)
300k+ 90/110's arn't imposible, but it depends how much time, effort and cash has been spent maintaining them
at the end of the day if its in good nick, at the right price, then why not
although I would have thought that an older 80k to 120k landrover would stand a better chance of being in good nick (for the same money ??)
mcerd1
posted on 18/9/06 at 01:19 PM |
No Landrover has ever be 'reliable'
its a fact of owning one, there is always something needing done or that could be done
just my 2p's worth
[Edited on 18/9/06 by mcerd1]
posted on 18/9/06 at 01:38 PM |
I think that a pretty pessimistic estimate. There must be literaly hundreds of thousands, maybe even millions of cars of that age with far higher
mileage than that, especialy diesels.
oliwb
posted on 18/9/06 at 01:39 PM |
200,000 miles in 11 years seems a lot??? Ex-electricity board landy or similar??? Could be OK could be a wreck hard to say, wouldn't outright
dismiss on that alone though....Oli.
StevieB
posted on 18/9/06 at 01:54 PM |
Assuming it's a defender, it'll be fine. Everything it easy to replace and cheap enough as well.
I once tried to run a Land Rover into the ground over Catterick driver training area and simply could get the better of it - and it was an old,
battered model, not one of the new Wolfs (that are ten times better again!)
caber
posted on 18/9/06 at 03:01 PM |
Milage on Land Rover irrelevant! What has it done, where has it been, how well has it been looked after? Is the gearbox noisy? What is crank case
pressure like, does it smoke out the oil filler after running for a while? Where are oil leaks? diff pinion seals will have been re done by now,
check for oil at the handbrake drum from Crankshaft seal, Is it original engine and turbo? do the axles whine ? is tere a lot of backlash in the
transmission?
Check chassis carefully for rust especially under any recent re-coating byg screwdriver hit hard! If the main members don't ring like a bell if
dead sounding walk! Check bulkhead at the usual places, bottom of A posts particularly also the bottom corners of screen surround.
Finally put your fingers through the bottom of the door frame point out it will need new doors and get a few quid knocked off, If this doesn't
happen then the motor has been looked after!
Caber
PS to mcred1 Land Rovers are as reliable as the maintenance given to them! People slag them off but forget that they have almost all outlasted
contemporary cars and the relaibility should be judged by the standards of the time they were built not against brand new cars all electronicy that
will die well before the Land Rover you are comparing it too! In 10 years of ownership I have only had AA out twice, once due to a failed master
cylinder that was only a few weeks old (thanks Lucas) and another time to a failed ignition module, I was too tired to put the points back and had no
timing tools as it happened the coil was fried as well still not sure what fried what on that one!
Lawnmower
posted on 18/9/06 at 03:18 PM |
Thats is so true, I have owned 2 landy (S2, & S3) always got home, possibly not fully functioning, but never stranded. But its the reason I have
AA cover.
Have however been left stranded by 3 year old vauxhalls astra, mazdas and Rovers!.
The car above is a disco, so has probably done 20k miles a year, sound like a motorway cruiser to me. It also from a garage, and apparantly the
bodywork is straight.
It has to be a landy, cos I want to play in it at weekends!
Rang garage up, 2 previous owners on the HPI check, lots of paperwork, emmaculate.
[Edited on 18/9/06 by Lawnmower]
posted on 18/9/06 at 03:51 PM |
well my 31 yr lightweight is still going strong - only time it ever broke down was due to after market parts - facet fuel pump and lumentiont box -
breaking.
dunno much about discos nor their pricing but there is loads of them so don't buy the first you see - and take someone with ya who knows what to
look for - the boot floor is notrorious for rusting.
andybod
just brought volvo 850 t5 with 162000 still pulls like a train had a bit of fun with an audi tt on sunday but as regards landrover with 200k be
very carefull find out what work has been carried out on transmission and steering and suspension expect to rebush and replace plenty of ball joints
check excessive backlash in transmission also check carefully for corrosion on boot floors and sill's and of course it'll leak oil
everywhere but cheap enough to repair if you are prepaired to spend a few weekend s working under it
TPG
posted on 18/9/06 at 04:53 PM |
I would buy high mileage,But i'd be really careful of any Landrover product.I've seen some 2000/2001 discos needing all the
'leveling pipes replacing.with just 80k on the clock.Landrover are still having a terrible time with quality control.It is better than it was
but.....That said you have to take each car as it stands on 4 wheels.I'd not pass a W124 Merc with 300k for £500....Right.Just reread the
orginal post.No.£2-2500 in Yorkshire will get a "good one" for that age.The trail boys are paying less than that for one to chop.Sadly it
is a case of looking about.'Trader always seems to come up trumps.eBay doesn't.Just my opinions....
[Edited on 18/9/06 by TPG]
..Which was nice..
mcerd1
posted on 18/9/06 at 05:04 PM |
Don't get me wrong here, I didn't mean that they wouldn't get you home - just that you always need to fix something or other that
isn't quite right
My dad's nearly always had a landrover of some kind or other (useful if you live and work on farms) for the last 12 years its been a 89'
110, it had a new 200 tdi fitted (just a year before we got it) at that time it had 90kish on the clock and was a very tidy car
its been serviced every 5000, new clutch (when the releace arm failed - std rover part - only time its ever needed a tow home), new chassis
(galvanised), new shocks, new rear tub, new sills, gearbox re-build, new fuel tank (SS), 2 exhausts (SS this time) and curently needs a bulkhead and
could do with 5 new doors and a re-spray
add to that just about every seal, bush, ball joint and the oil presure switch that went last week... and loads more I can't remember but it is
at 130k now
My point is only that it can be alot of work in running one sometimes - but that said I quite like them
simple is always better, have you seen the number of nearly new cars in scrap yards with eletrical failure !!!
Simon
posted on 18/9/06 at 07:01 PM |
I bought a 1990 RR Classic in 1999 with a genuine 205,000 on the clock, but I knew the car was well looked after (it was immaculate), and
whenever it needed work, it was done. The engine had just had a (v. exp) rebuild.
Only had one prob shortly after I got it, it wouldn't turn over, which I discovered in about 5 minutes was down to the ig switch wire on starter
had came off.
Superb car. Love another.
Simon
wilkingj
posted on 18/9/06 at 07:55 PM |
Christ!..
My 1984 110 has 194k on the clock, and I would go anywhere in it at the drop of a hat.
I have owned it for 11 years its a good motor.
Cheap spares, readily available, Piss easy to fix. Big Boys Mecano kit.
Its let me down 2 times in 105k miles.
1. Blown original engine (N/A Diesel 90k)
2. Clutch flexi split Fixed by the AA in an hour of getting there including going and getting the hose.
I cant complain it gets a lot of abuse as my daily ride. Tows like a train.
I am well pleased with mine.
OK, so it needs maintaining, what doesnt. Just give it plenty of fresh clean oil at the right intervals and change the filters. Grease everytihng up,
and spray the inside of the chassis with Waxoyl. Or get a Galvanised chassis like mine.
Oh... Sorry I forgot, most of you have never seen a car with grease nipples on every ball joint. You Old technology requiring old style
maintenance.
They are as reliable as anything else, providing its properly maintained. They take a lot of abuse, and it not maintained they will give trouble...
just like anything else.
Best Regards
Geoff
http://www.v8viento.co.uk
