Author: Subject: Wheel nut tapers, different?
the_fbi
posted on 24/9/06 at 07:46 PM Reply With Quote
Long story, but I'm short of a few wheel nuts, I only currently have 2 per wheel.
Bought some tapered nuts a while back, they have a separate, although non-removeable and fitted to the nut, tapered washer.
Put a few onto one of my wheels, but the nut hits the wheel before the taper does.
From memory they were 60 degree taper and supposed to be for a Ford alloy, I'm using them on a Caterham "prisoner" alloy so they should be OK.
Are there different tapers available or have I just been unlucky?
Only solution appears to be to get the protruding nut part turned down.
oliwb
posted on 24/9/06 at 07:52 PM Reply With Quote
You could just go to a scrappy armed with a wrench and remove the nuts you need from various fords. Or is it not that simple for some reason.....Oli.
posted on 24/9/06 at 08:00 PM Reply With Quote
Sounds like you need the straight shouldered RS alloy wheel nuts, they are not cheap.
the_fbi
posted on 24/9/06 at 08:04 PM Reply With Quote
Nah, I definately need tapered ones.
These are the ones I've got, as you can see the "nose" sticks out too far so the taper washer doesn't touch the wheel, hence it rattles
Wheelnut
Wheelnut
lexi
posted on 24/9/06 at 08:52 PM Reply With Quote
I think you need the Capri Laser type. I`m
short of one of them myself. Looked through all the alloy wheel companys catalogues.....still can`t find a prisoner model
Alex
[Edited on 24/9/06 by lexi]
Chippy
posted on 24/9/06 at 10:41 PM Reply With Quote
Demon thieves do all the diferent type of wheel nuts, give them a bell, sure to sort you out, (at a price). Regards Ray
Ratters
posted on 25/9/06 at 07:50 PM Reply With Quote
Speedshack are pretty good for wheel nuts too.
daviep
posted on 25/9/06 at 09:52 PM Reply With Quote
Please let us know what the solution is as I also have exactly the same problem!!
Cheers Davie
posted on 25/9/06 at 10:42 PM Reply With Quote
If you are using Sierra wheel studs they are not threaded all the way to the bottom, they have a shoulder that the nut hits before it tightens to the wheel in some cases.
the_fbi
posted on 25/9/06 at 11:14 PM Reply With Quote
Good tip, better check that ASAP.
Marcus
posted on 26/9/06 at 11:08 AM Reply With Quote
Quick solution would be 5mm spacers, available almost anywhere.
Marcus
Because kits are for girls!!
