Author: Subject: Camber gauge
stig2
posted on 25/9/06 at 02:17 PM Reply With Quote
Camber gauge
Before I purcahse has anyone bought one of these @ Sealey camber & caster gauage. Are they any good.?
http://www.ccw-tools.com/product.asp?P_ID=4822
MustangSix
posted on 25/9/06 at 03:21 PM Reply With Quote
I have the same device under a different name and it is remarkably accurate for caster/camber readings.
One thing you need to be sure of is to have the car on a level surface and have good points to attach the device. I use chalklines drawn with a common protractor to get my 40 degrees of wheel rotation for caster measurements.
Getting a really good alignment means comparing the rear wheels to the front, so some more string and level work is needed to make those measurements.
The final tool needed is some sort of toe gauge. You can make one of those out of lumber and nails or pipe.
pewe
posted on 25/9/06 at 04:44 PM Reply With Quote
Just bought an "Angle guage for body / panel alignment" for £6.00 on eBay - item no. 170031677311. Worth a punt and combined with the instructs. on Sealey's Auto service site I reckon I should be able to get it pretty accurate. Cheers, Pewe.
posted on 25/9/06 at 07:03 PM Reply With Quote
Where abouts are you Stig2 ?, If your local to me I have one you can borrow
