Author: Subject: Electric power steering
Macca
posted on 19/5/03 at 12:15 PM Reply With Quote
Does anybody know of any cars that use an electric motor to power the power steering pump.I have been told that subaru(spelling?)may of fitted them.I want one to power a hydraulic winch so it can still be used if the engine is not running.Some tipper trucks have them be are usually quite large.
Cheers Col
Jon Bradbury
posted on 19/5/03 at 12:20 PM Reply With Quote
MGF has electric power steering. Its rubbish...
GO
posted on 19/5/03 at 12:40 PM Reply With Quote
MR2s have electric power steering, the mk2 (the rounded one).
Mark Allanson
posted on 19/5/03 at 12:53 PM Reply With Quote
My Fiat Punto has electric power steering and is about the best I have driven, it also has twin setting, the 'city' setting is massivly over powered, but normal is excellent
ned
posted on 19/5/03 at 01:12 PM Reply With Quote
my 306 has power steering, I'm assuming its electric!?
beware, I've got yellow skin
MK9R
posted on 19/5/03 at 01:24 PM Reply With Quote
Mercury outboard engines make them, but they do cost 800 snotters!
[Edited on 19/5/03 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
stephen_gusterson
posted on 19/5/03 at 02:09 PM Reply With Quote
traditional power steering is hydraulic......is the best assumption.
my wifes new megane (the big bum one - the car not the wife) has lekky steering.
renault parts are really expensive tho!
what MAY be worth a try id the abs pump assembly from a mk3 granada. I have no idea how, but a robot wars robot used it to power hydraulis on a 'bot,
atb
steve
Alan B
posted on 19/5/03 at 02:16 PM Reply With Quote
What is the current snotters to dollars conversion rate?.....
ned
posted on 19/5/03 at 02:32 PM Reply With Quote
depends how many tissues you use Alan.
MK9R
posted on 19/5/03 at 02:37 PM Reply With Quote
2.7 snotters = 1 American squit
Cheers Austen
RGB car number 9
www.trackace.co.uk
paulf
posted on 19/5/03 at 09:19 PM Reply With Quote
I think that electric power steering is purely electro mechanical and has no hydraulics, i have seen a unit off a fiat punto and the motor is quite small.
We have a battery powered hydraulic bin hoist at work and the motor on that is like a small starter motor and draws 42 amps when running.Maybe you could adapt a starter motor or possibly a dynamo from an older car.i have heard of people using the old lucas type dynamos for powering kids cars and think they have been used in robot wars as motors.Other than this find a scrapdealer that deals in industrial machinery and have a look around. Batttery pallet trucks may be the ideal source and would supply pump and motor complete.
Paul.
Cheers Col
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 19/5/03 at 09:20 PM Reply With Quote
Electric powersteering
Try the EPS-sytem used on Corsa's 1993-2001. They've got an elektric motor builinto the steering collumn. You could use the complete collumn including the contol unit. Should be available at a scrapyard/recycler.
Yuo don't have to worry about steering-racks, pumps, oillines and powersteering-fluids.
Greetingz, Rob.
Sex, drugs and Supersevens
Scouse Monkey
Clio has electric steering too. Saw a Dynamique ('sporty' model) being broken on Ebay I think.
[Edited on 19/5/03 by Scouse Monkey]
Marcus
posted on 19/5/03 at 10:05 PM Reply With Quote
The rally guys use Citroen Saxo electric pumps and Corsa racks for Vauxhall Novas. Works a treat
Marcus
Marcus
Because kits are for girls!!
chrisg
posted on 19/5/03 at 10:13 PM Reply With Quote
Marcus,
If i'd known anything about vauxhall Nova's I'd have kept it to myself - people might draw certain conclusions.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
posted on 20/5/03 at 09:22 AM Reply With Quote
My Clio had it as well till some git nicked it, the car not the pump.
yours, Pete.
jollygreengiant
posted on 20/5/03 at 09:51 PM Reply With Quote
Most common application on modern cars is for a hybrid system. Sensors on the column tell a control unit if you move the column and this in turn operates an electric motor connected directly to a power steering reservoir usually connected directly to the power steeering rack. Probably the most common usage of this type of hybrid is on Vauxhall Atsra's.
Hope this helps
And the system fitted on MG F's is *&*(*&****
Enjoy.
Macca
posted on 20/5/03 at 11:15 PM Reply With Quote
Big thanks to all, looks like it more common than I first thought!
Col
