lightspear27
posted on 28/9/06 at 12:00 PM |
DIY Corner Weight Gauge
Well ... I think I'll go the DIY way and build my own Corner Weight Gauge.
I have already ordered a hydraulic pressure gauge (1000 psi ... converted that's 1000 lb ... am I right?) from eBay for 4£ and I am now looking
for a clutch slave cylinder.
A little bit of metal fabrication, a little bit of plumbing between the slave cylinder and the gauge and I'll have my Corner Weight Gauge.
I have just one question :
Will all clutch slave cylinders be good for my application? Or do I have to look for a specific model?
I will put a picture of a DIY Corner Weight Gauge found on the Net in my archive ... I think the article it come from was posted here a few weeks or
months ago.
Thanks in advance for your advice,
Stefano
mookaloid
posted on 28/9/06 at 12:10 PM |
I would think a nice small cylinder would be suitable - bear in mind that it needs to fit under the wheel rim to lift the car up. not all wheels
easily lend themselves to this.
It doesn't matter about converting 1000psi to lb's as you only need a comparitive reading from wheel to wheel IMHO of course.
Mark
lightspear27
posted on 28/9/06 at 12:20 PM |
RIGHT!
Do you know what car a "nice small cylinder" could come from?
boxfile
posted on 28/9/06 at 12:22 PM |
How do you fill the slave cylinder with fluid and bleed it?
I am not a number!
russbost
posted on 28/9/06 at 12:47 PM |
Old (not BMW) Mini had a reasonably small slave cyl. also has 2 good size lugs with bolt holes as I assume you'll need to attach it to
something? Bleeding shouldn't be a problem as it has a nipple on the rear end - strange place to have your nipples
lightspear27
posted on 28/9/06 at 01:29 PM |
Which One?
Thanks for the answers.
I found 2 different slave cylinders for the classic mini ... I understand some are pre-verto and some are for the verto clutch. (see in my photo
archive)
Which one should I choose?
mookaloid
posted on 28/9/06 at 02:21 PM |
You might even be better with a wheel cylinder off mini front brakes they are tiny if I recall and the piston pokes out a bit which is good.
I would fill the system with a syringe with the piston at it's maxumum travel then push the piston back in a bit to expel any air through the
bleed nipple which you have positioned at the highest point.
Mark
[Edited on 28/9/06 by mookaloid]
posted on 28/9/06 at 04:39 PM |
It may be useful to be able to estimate wheel weights rather than just doing comparative measurements. Knowing the diameter of the piston in the
slave you can easily translate pressure to force
Pressure = Force/Area
Area = 3.1415*Radius*Radius
Keep all units the same for simplicity, e.g if using a mini clutch slave, it has a bore of 7/8". If the pressure gauge reads in PSI, then the
conversion factor is
Area = 3.1415*7/8*7/8 = 2.405
Simply multiply the pressure reading in PSI by 2.4 and you get the force acting on the piston in pounds.
This also gives you an idea what your pressure gauge needs to be rated for. If an average CEC Locost weighs 600kg, corner weight will be approx
150kg, which is 330 pounds. With a mini clutch slave this gives a pressure of 137.2 PSI.
[Edited on 28/9/06 by MikeRJ]
Simon
posted on 28/9/06 at 09:03 PM |
Alternatively, do what I did and buy 4 sets of bathroom scales (used 2 per wheel) from Argos for £4 each
Simon
lightspear27
posted on 29/9/06 at 11:25 AM |
Thanks to all for the advices
lightspear27
posted on 29/9/06 at 11:26 AM |
whitestu
posted on 29/9/06 at 03:26 PM |
I was thinking of doing this after seeing scales in ADSA for less than £3. How did it work?
Stu
Simon
posted on 1/10/06 at 12:52 AM |
Stu,
Fine iirc
Just make sure you spread the load across each set of scales. They are (as you can appreciate cheap) so subject to jamming (and giving false readings)
if weight is applied in wrong place.
Simon
posted on 1/10/06 at 09:15 AM |
You could try motorbike rear brake master cylinders, there are plenty to choose from. You could mount them in some form of frame with a plate for the
wheel connected by lever arrangement to the cylinder to get the range you want. Cheapo scales sounds easier though.
