New Topic New Reply
Author: Subject: Help Suspension Angles!!
davidwag
posted on 1/10/06 at 12:27 PM Reply With Quote
Hi All,
Had a customer bring his recently purchased kit car in for an MOT.
When I drove it up the road I nearly got out and walked back
Home build special using cortina front end, but all the pick up points are in the wrong place. To say that the handling is unpredictable is an under statement
Any Ideas to inprove geometery without cutting the front end off and starting again?
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Midge%20front%20suspension.jpg
[Edited on 1/10/06 by davidwag]
robertst
posted on 1/10/06 at 12:33 PM Reply With Quote
oh man you're making me worry about if i did put mine in correctly!
Tom
robertst
posted on 1/10/06 at 12:36 PM Reply With Quote
whoa i take that back!
that looks so odd doesnt it? the nosecone is way to high, the wishbones look like they were taken entirely from the cortina... Rescued attachment Midge front suspension.jpg
Tom
davidwag
posted on 1/10/06 at 12:40 PM Reply With Quote
Yes wishbones are from cortina,
How do i get the images to attach?
posted on 1/10/06 at 12:45 PM Reply With Quote
Chop it up and build a locost.
Thge springs are too strong, they're lifting no weight so it will ride like a romping dog. Put a couple of bags of sand in the nosecone to weigh the front down and pull the wheels in at the top. Put some lights in the shed as well Rescued attachment Midge front suspension.jpg
davidwag
scotty g
posted on 1/10/06 at 12:48 PM Reply With Quote
Its an old Robinhood, even RH owners don't like these ones!
davidwag
posted on 1/10/06 at 12:56 PM Reply With Quote
Yes if it was my car I WOULD cut it up and build a locost.
But as it belongs to a Customer I have to try and persuade him to part with his money after i tell him his new purchase is a death trap!
Ps On the log book its called a Ford Midge 2 seater sports.
Some more photos in my archive for your ammusment
Danozeman
posted on 1/10/06 at 01:11 PM Reply With Quote
THat looks horrible!!
Look at the angle of that lower ball joint.
If theyr standard springs off the cortina theyl be way to heavy for it.
Dan
davidwag
posted on 1/10/06 at 01:58 PM Reply With Quote
I now done a bit of searching on the web and think what it is is a kit called a locust.
Box tube chassis and wooden tub body.
There is a report on the owners club web site about converting to tube wishbones.
Would like to run the design through some software before i decide to advise my customer to go down this route as the original chassis designer didn't have a clue so is this going to be any better?
Does anyone have any links to some software?
Mark Allanson
posted on 1/10/06 at 02:01 PM Reply With Quote
Remember, a std cortina front end runs with 1°30' of castor
StevieB
posted on 1/10/06 at 02:37 PM Reply With Quote
I think the best advise you can give your customer is to go to Stuart Taylor, GTS et al, and buy a basic locost starter pack and transfer all the relevant bits across, and then throw the reat away
jack trolley
posted on 1/10/06 at 03:14 PM Reply With Quote
Cortina front suspension is attached to a bolt-on subframe - easy to bolt on to a new chassis.
But it will be heavy and the springs will be too stiff for a 7.
Guinness
posted on 1/10/06 at 03:42 PM Reply With Quote
We had a guy come out on a blat into Scotland once with a similar car. We met up in Tesco's car park and when he did a u- turn the wheels nearly fell over and the tyres were squealing at 5mph! He spent most of the day spinning it!
Mike
roadboy
posted on 1/10/06 at 04:23 PM Reply With Quote
That car should never have been allowed on the road, it is a deathtrap with suspension like that.
Regds
Ian
Jude Performance Services
davidwag
posted on 1/10/06 at 04:48 PM Reply With Quote
Now you can see the reason for the SVA !!!
This was build pre Sva
Its got about 6 previous MOTs with it, I think the tester must have looked at it and didn't know what to fail it for
skydivepaul
posted on 1/10/06 at 07:27 PM Reply With Quote
looks like a friggin lotus seven monster truck.
my advice would be set it on fire and push it off a cliff
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
posted on 1/10/06 at 07:31 PM Reply With Quote
No it's not. I had one of those abortions (RH S7), only bought it to use as a donor. The RH used the whole Cortina front subframe, whereas this doen't seem to. The nose on the RH was roughly in the right position too.
It could well be a Midge looking at it, but they were designed as an old MG replica. Looks like someones bunged a 7 nosecone on and hoped for the best.
Have a look at the chassis in this auction: http://cgi.ebay.co.uk/MIDGE-2-SEATER-KIT-CAR-UNFINSHED-PROJECT_W0QQitemZ300002561315QQihZ020QQcategoryZ29750QQcmdZViewItem
DIY Si
posted on 1/10/06 at 07:54 PM Reply With Quote
Are steering componenst allowed to be welded for the mot? Since that track rod end has a welded extension, which I though was a bit naughty? Otherwise, tell him to bin it and get a proper car!
Sun Tzu, The Art of War
posted on 1/10/06 at 09:37 PM Reply With Quote
If it is a Locust (both Midge and Locost made by J.C. original and appear to have simmilar chassis), then perhaps you can find some more information at the Locust Enthusiasts website
http://www.locustenthusiastsclub.fsnet.co.uk/about/about.htm
waterrat
posted on 22/10/06 at 12:21 PM Reply With Quote
stearing rack
just a thought from looking at the photo, i think the uprights have been fitted upside down, isn't the steering rack sposed to be fitted so that the it attaches to the uprights at the top behind the shocks. i had been told that this will meen that the wheels will want to run straight when not beeing steered.
flak monkey
posted on 22/10/06 at 12:45 PM Reply With Quote
The uprights are on the right way up. The cortinas steering arms are ahead of the stub axle, not behind it!
Sera
http://www.motosera.com
posted on 22/10/06 at 02:18 PM Reply With Quote
They've moved the website
to locust.org .
posted on 23/10/06 at 07:18 AM Reply With Quote
Spartan used a similar setup -- complete Cortina front and rear truly awful to drive.
Many Locust were changed to 5 link.
Actually not a lot wrong with the suspension although the camber and other angles are all wrong there is nothing unsafe about provided the standard Cortina bump stops stop the suspension movement before the lower ball joint binds up. But a whole Cortina suspension is just not suitable for a lightweight sports car.
New Topic New Reply
