soggy 3
| posted on 2/10/06 at 02:27 PM |
zx9 carbs
i have just fitted zx9 carbs to my cvh i am just fitting the fuel line but theres two whats the story.
[Edited on 2/10/06 by soggy 3]
ch1ll1
| posted on 2/10/06 at 02:30 PM |
get a t-piece and join them together
soggy 3
| posted on 2/10/06 at 02:45 PM |
Is that a guess or an answer?
daviep
| posted on 2/10/06 at 03:20 PM |
The two hoses shown look like the hoses which connect to the cooling system for the carb heating. What make are your carbs and I'll have a look
for some info.
There is a pic in my archive of mikuni's with the fuel inlet marked.
Cheers Davie
givemethebighammer
| posted on 2/10/06 at 03:22 PM |
That's the way I've done my blackbird ones, so I guess that's an answer.
Danozeman
| posted on 2/10/06 at 03:29 PM |
Yep a t piece and join them. Thats how mine are...
Dan
daviep
| posted on 2/10/06 at 03:41 PM |
Sorry I stand corrected !!!
Cheers Davie
soggy 3
| posted on 2/10/06 at 04:35 PM |
Cheers guys just the ticket
jacko
| posted on 2/10/06 at 05:46 PM |
The fuel pipe is in the middle about 10mm the 2 pipes are water if they are e1 carbs
Jacko
Coose
| posted on 2/10/06 at 07:28 PM |
I thought they were the flow and return for the carb de-icing circuit. Isn't that the fuel inlet behind the tickover adjustment screw?
Spin 'er off Well...
Guinness
| posted on 2/10/06 at 07:36 PM |
Got to agree with Coose on this one, carb warmers. Stops your carbs icing up on cold mornings. On the ZZR one end attaches to the water rail as it
exits the block, but before the thermostat, and the other returns to the water pipe as it comes back from the rad to the water pump.
Shouldn't think it neccessary on a 7 with under bonnet temps being higher than on a bike / less winter running, but I may be wrong.
Mike
Alistair
| posted on 2/10/06 at 07:37 PM |
Those are the de-icing water pipes. Bin them.
soggy 3
| posted on 3/10/06 at 03:19 AM |
lucky you spotted that guys that would have been hard trying to start it!
can i just plug the water pipes up?
thanks again
[Edited on 3/10/06 by soggy 3]
Coose
| posted on 3/10/06 at 07:31 AM |
Just pull the hoses off and leave them! You won't get water in there unless you put it there!
G.Man
| posted on 3/10/06 at 07:46 AM |
Yes those pipes are DEFINITELY the carb warmers..
They aim to prevent carb icing on cold humid days, but they dont really work that well..
If you plan to drive the car on cold misty days then you can connect them to your cooling system, but i wouldnt bother...
Just remove them
Opinions are like backsides..
daviep
| posted on 3/10/06 at 08:13 AM |
Looks like I wasn't talking shite after all
soggy 3
| posted on 3/10/06 at 10:29 AM |
cheers
