New Topic New Reply
Author: Subject: Locost Westfield
Rob
posted on 25/5/03 at 09:43 AM Reply With Quote
Locost Westfield
After Getting A 1/18th Scale model of a Lotus supper 7 A few Xmas's ago.
I have just started looking into what is needed for a build. Reading through Magazines, Westfield do a single donor starter kit called the westsport SDV. the kit comprises of Space Frame Chassis, Spare Wheel Carrier, Top Front Wishbones, Bottom Front Wishbones, Engine Mounting Brackets, Pedals Including Master Cylinders (Floor Mounted), Brake Lines, Aeroquip Fittings And Tee Piece (any help on what this is), Aluminium Panel Set Including Floor Pan, Seat-Back, Centre Tunnel And Scuttle, Nuts, Bolts, Rivets And Suspension Bushes, Chassis Plate, Wing Brackets, Rear Uprights, Top Rear Wishbones, Bottom Rear Wishbones, A Complete Set Of Self Coloured Body Work Including Rear Body Section, Scuttle, Bonnet, Nose, Screen Fillet, Wings (Choice Of Swept Or Cycle Design) And A Boot Box, All In A Choice Of Colours.
The donor car is any siera with a pinto engine.
To me this sounds ok to give me a good start. But I would be greatfull to any of you expirienced builders for you views.
locodude
posted on 25/5/03 at 11:38 AM Reply With Quote
A Westfield certainly isn't a Locost, or a LOW cost way of going about building a 7 based roadster. There are many cheaper alternatives. This forum was basically set up to help builders of Locosts. i.e people who want to build their cars from the ground up, including the chassis. It has evolved from this original concept however and now deals with a variety of different 7 based kits. The Westfield isn't one of them though. As for the phrase 'single donor' how come it needs a mk2 escort steering rack then? Oh and the 'tee' piece is a 't' piece for the brake lines.
I would suggest that if you have the money then go ahead and buy yourself a 'cheque book seven' but don't expect any help from the people on this forum. There is a dedicated Westfield forum for that!
Good luck in your endevours
DoctorFunky
posted on 25/5/03 at 03:32 PM Reply With Quote
Have a look at the MK Indy. The comprehensive kit is the same price as the Westfield and you would find a lot of support from people on this forum. There is even a seperate section for the MK.
Glad I didn't build a Tiger
chrisg
posted on 25/5/03 at 03:57 PM Reply With Quote
Not wanting to argue with a doctor but:
Mk Indy starter kit - £1169.12
West field SDV starter kit - £2250
Both including Vat
not exactly the same provided, but the MK has some things the Westfield don't and vice-versa.
Mk's comprehensive kit is cheaper than Westfield's starter kit! (£2174.13)
Over a grands difference, and then check out the differece in parts you may need, Westfield parts prices make your eyes water!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
DoctorFunky
posted on 25/5/03 at 05:29 PM Reply With Quote
I agree a Westfield is a much more expensive option in the long run, but I think you miss my point. The Westfield starter kit features much more than the Indy starter (ie pedal set, brake lines, aluminium panel set including floor, bushes, bolts and rivnuts and engine mounts. The only difference between this and the comprehensive Indy kit is the shocks and roll bar. Also it is now priced at only £2000, cheaper than the Indy comprehensive kit. Even adding £359 for shocks from Westfield it is still only £200 dearer than the Indy.
But, as you say, other spares from Westfield are incredibly over priced, so I would still go for the Indy.
ChrisW
posted on 25/5/03 at 07:57 PM Reply With Quote
Don't forget our new sponsor either *cough*
Chris
My gaff my rules
locodude
posted on 25/5/03 at 09:56 PM Reply With Quote
Yeah, 'cos that big Viento thing is such a good looker!
ChrisW
posted on 26/5/03 at 08:34 AM Reply With Quote
Yes. That's why I'm building one!
Chris
My gaff my rules
zetec
posted on 26/5/03 at 08:42 AM Reply With Quote
I think if I did it all again I would have to look at the Westfield option if only for the much better bodywork. The MK chassis is just as well made as any but the fibreglass panels are a pain. Best bet if going cheap Westfield route is to get a rolling chassis and source everything else yourself. That said mine has turned out very well. It seems as MK success has taken them by surprise and R+D for the Indy has been put on the back burner.
Jasper
posted on 26/5/03 at 11:26 AM Reply With Quote
Trouble with Westy bodywork - smack the rear arch and you gotta replace the whole back and sides.
Stu16v
posted on 26/5/03 at 11:34 AM Reply With Quote
I must admit, I'm quite surprised by some of the negative responses towards the Westfield SDV.
Err, dont MK (and most of the others seemingly) offer this service already, even down to offering turnkey cars? Exactly the same as Westfield as I see it.
There are more expensive alternatives too, inculding what is supposed to be a Locost. You pays yer money etc etc.
Cant argue the point that some of Westfields other prices are a tad 'extreme' to say the least. But there again, you dont have to buy the other stuff from Westfield, as Zetec suggests.
And I reckon the Westy will hold second hand values better, should you be in the unfortunate position to have to sell your car.
It can only be good news for us mere mortals if the likes of Westfield are dabbling in the Locost end of the market (like it or lump it, it's true), the quality and value of the products offered by MK, Luego etc is already first class, and is likely to get better still with the fresh competition.
And I wonder where the 'inspiration' for the original RC chassis would come from if it wasnt for the Westy?
theconrodkid
posted on 26/5/03 at 01:44 PM Reply With Quote
yo zetec when you say mk bodywork is a pain,in what way do you mean,ive got that delight to do and any info would be apreciated
who cares who wins
pass the pork pies
zetec
posted on 26/5/03 at 03:58 PM Reply With Quote
The first problem was the scuttle, when I came to fit it I found the gel coat was full of bubbles along one bottom edge had to drive to Midlands to get another even though it was faulty when sent out. The send item was the bonnet, it was 1/2 longer one side than the other and is a very poor fit around the scuttle. When I talked to MK about it they agreed it was crap and said they use another supplier now! Also just noticed the nose cone is not true, but the number plate will hide that. If I had bought a Westie I would have been on the phone insisting they sent new parts rather than me do the leg work to get it sorted, but the lads at MK have been very helpful in other areas I have lived with it. It must be hard moving from chassis fabricator to kit manufacturer in such a short time.
theconrodkid
posted on 26/5/03 at 05:40 PM Reply With Quote
thanx zetec,they are a great bunch and i can see the pressure they are under,mine was made very recently so fitting shouldnt be a problem
who cares who wins
pass the pork pies
locodude
posted on 26/5/03 at 06:27 PM Reply With Quote
Doesn't anybody on this list know what 'tongue in cheek' means. Thought not
Meant it about the Viento tho', sorry ChrisW just my personal taste.
chrisg
posted on 26/5/03 at 08:42 PM Reply With Quote
hey, lets ,like all get along, live and let live.
Except anyone who didn't build their own chassis - they should be burnt at the stake.
Chris
And if Luego are "our" sponsor, where's my share?
posted on 27/5/03 at 06:41 PM Reply With Quote
Yes, lets start our own club, the home made locost builders club and have a website called locostbuilders or something like that.
Doh!
chrisg
posted on 27/5/03 at 06:49 PM Reply With Quote
You might have got something there Pete,
Something along the lines of, oh, I dunno, Locostbuilders.co.uk?
Yeah, could work
Chris
We could have a sister site called"Locost_type_assemblers. co.uk
UncleFista
posted on 27/5/03 at 08:50 PM Reply With Quote
Also resale value should be taken into consideration. Even the best Locost isn't going to sell for more than a Westfield.
Not an issue if you intend to keep it forever, but who's gonna stop at building one ?
Tony Bond / UncleFista
kingr
posted on 28/5/03 at 08:28 AM Reply With Quote
How about locostinspiredbuilders.co.uk?
Kingr
ChrisW
posted on 28/5/03 at 11:13 AM Reply With Quote
Each to their own... I really like the Viento hence why I approached Luego to help with the site.
You're using your 'share' now. The site is (still) free, and I now have some time to fix all the things you lot moan about!
Chris
My gaff my rules
Metal Hippy
posted on 28/5/03 at 05:19 PM Reply With Quote
That'll be me then....
Cock off or cock on. You choose.
chrisg
posted on 1/6/03 at 07:01 PM Reply With Quote
I'll stop looking - send me a cheque.
Chris
stats
posted on 25/6/03 at 09:16 PM Reply With Quote
westfield test drive
Went for a test drive in a westfield I hope my locost dosn't end up the same! allbeit a positive drive I was told in a very nice way that I could put one on the road for around K6.5-K7 and this all started with a book that promised me a car for £250. it just cost me that for a welder and i bought a built chassis???Duh
New Topic New Reply
