RobC
| posted on 19/10/06 at 02:43 PM |
SVA Check on wheels and hubs
Just a quick one... i have a set of Capri Laser (13" wheels on the car but the studs I have to use are not the same dia. as the holes in the
wheels... Any ideas if this is going to be an issue.. As I can sort it if it is...
Ta kindly
R
theconrodkid
| posted on 19/10/06 at 02:47 PM |
they wont be,its the taper of the wheel nuts and the spigot that holds them in place
who cares who wins
pass the pork pies
RobC
| posted on 19/10/06 at 02:50 PM |
So it will be ok then....
very quick reposnse.. magic TA!
Johnmor
| posted on 19/10/06 at 05:10 PM |
SVA
They will check to see if the taper on the wheel nuts matches the taper on the wheel though.
Just in case.
Mark Allanson
| posted on 19/10/06 at 06:14 PM |
If you have the standard chromed swivel taperd wheel nuts, they will not even bother to check the nuts. People forget that the SVA testers live eat
and breathe cars, they really know their stuff (and VERY wise to bodges, dodges, and mythical pass cons!)
wicket
| posted on 19/10/06 at 07:38 PM |
We have the proper tapered chrome nuts and we had to remove one at SVA to check that they had the correct taper washer and number of threads engaged.
flak monkey
| posted on 19/10/06 at 07:47 PM |
How many threads should there be engage on wheel nuts? IIRC the recommended is 1.5x the thread dia on normal applications, which would be 15mm on ford
hubs.
I have the nuts that came with my wheels, they dont have the swivelling taper bit on though.
Sera
http://www.motosera.com
wicket
| posted on 19/10/06 at 09:15 PM |
See here
http://www.needforspeed.co.uk/htmlpages/TechWheels.htm
Capri Laser wheels on standard Cortina hubs with 60deg swivel taper washers from Rally Design gives 10 turns engagement approx.
