Author: Subject: TRT propshaft
Arjan356
posted on 21/11/06 at 05:19 PM Reply With Quote
TRT propshaft
Hello,
I have a very klunky drive train in my Indy-ZX12, so I want a TRT propshaft. I can not find a company in Holland who makes TRT props.
I have a TRT propshaft from a 4x4 cossie but it weighs a lot more than a standard propshaft.
Does anybody have a picture from a custom made TRT prop, so I have an idea houw they look like.
Best regards,
Arjan
posted on 21/11/06 at 09:23 PM Reply With Quote
Hi Arjan,
Ours was made by Dunning & Fairbank based in Leeds, Yorkshire.
It 'looks' basically the same as a standard propshaft with no 'extra bits'. All the technical stuff is internally mounted.
They make the prop's for TVR... well, they did!
DIY Si
posted on 21/11/06 at 09:27 PM Reply With Quote
As hellfire said, the TRT bit, as shown on Cavin's top pic is the thicker end on the left. Otherwise the prop is the same as a 'normal' prop.
Sun Tzu, The Art of War
Avoneer
posted on 21/11/06 at 11:00 PM Reply With Quote
See here:
http://locostbuilders.co.uk/viewthread.php?tid=31716
Pat...
jambojeef
posted on 21/11/06 at 11:08 PM Reply With Quote
Thats interesting since mine looks loads different!
Its noticeably made from larger diameter toob at the rear and the rubber "filler" material is visible between the inner toob.
Obviously mine is made properly on Tyneside....
jambojeef
posted on 21/11/06 at 11:14 PM Reply With Quote
Like this: Rescued attachment untitled.JPG
DIY Si
posted on 21/11/06 at 11:21 PM Reply With Quote
It's because Cavlin's trt bit is in front of the centre bearing. That's why his and yours are different.
jambojeef
posted on 22/11/06 at 07:30 PM Reply With Quote
....and of course the bottom of the sea bed!
