mike smith1
posted on 23/11/06 at 04:53 PM |
Rover Metro GTa 1.4 8v K-Series
Look's like the girlfriends run around has dropped a valve, no compression to cylinder 2 and on removal of the rocker cover the hydraulic lifter
is easy to push into the valve.
Any one had any experience of rebuilding this engine, i have access to seat cutting and valve cutting gear.
Before i fork out for a haynes manual does anyone have any info for the timing etc
Any help much appreciated
Mike
angus.d
posted on 23/11/06 at 05:22 PM |
Mike
I have to admit it doesn't sound good. If the valve is stuck open it could have caused a lot of damage to the head and/or piston, particularly
if this happened while the engine was running or if the engine has tried to be started.
You won't really know until you take the cylinder head off.
A cheaper option could be to look for a lowish mileage 2nd hand engine from a crashed one etc.
Best of luck
Angus
posted on 23/11/06 at 05:24 PM |
Or do what that person did in one of the mags ?PPC or ?practical classics and put a VVC K series in it
mike smith1
posted on 23/11/06 at 06:20 PM |
She scares the crap out of me in it now!
Mike
hillbillyracer
posted on 23/11/06 at 08:31 PM |
If you want it to be slower, did they not do a 1.1 K series?
