jamesg20
posted on 12/12/06 at 01:25 PM |
Cam cover painting - I've done a search...
Can i paint a cam cover in standard paint or does it have to be HT or VHT?
Also if i donneed HT paint, surely i need HT laquer?
I've seen people using powdercoat but it's a a hassle i could do without, especially as on my last project the powdercoating on the
chassis was affected by the exghaust heat...
RazMan
posted on 12/12/06 at 01:30 PM |
In theory you can use standard bodywork paint but I would play safe and use an HT paint as it will have better resistance to oil & high
temperature - also they don't need a laquer.
[Edited on 12-12-06 by RazMan]
Raz
jamesg20
posted on 12/12/06 at 01:33 PM |
Cheers RazMan thats what i thought.... Problem being i can only find limited colours in HT paint... anyone know a good source for small quanitities?
posted on 12/12/06 at 01:51 PM |
if you can get red,yellow,black,white and blue, you can mix up your own colour - make sure you make up more than you need so you can touch up any
scrapes in the future.
In theory cam cover should be running at water temp so shouldn't get much more than 100 C.
muzchap
posted on 12/12/06 at 03:09 PM |
I painted mine with normal 2 pack and it's been absolutely fine - even with this summers extreme temperatures and the odd trackday.
You don't need HT paint - unless it's the block IMHO
Peope will always disagree - but hey, even if it flakes off after 2 years - is it such a hardship to repaint? That's what WINTER is designed for
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
the_fbi
posted on 12/12/06 at 04:11 PM |
Normal body paint has been fine on mine.
I'm not sure I agree with the "is it such as hardship to repaint?". Took hours of preparation to do this. In the flesh its a
stunning job.
What looks like orange peel, isn't, its the edge of the fluffy clouds.
[Edited on 12/12/06 by the_fbi]
NS Dev
posted on 12/12/06 at 04:30 PM |
standard paint is fine, if the cover gets too hot for it then the paint finish will be the least of your worries!!!!!
DaveFJ
posted on 12/12/06 at 04:31 PM |
spary cans of 'plasticoat' are available in loads of colours and apparently good for 150 degrees........
just a thought
Dave
NS Dev
even on a block you won't, I use industrial floor paint, tough as old boots.
if it gets too hot for it then you have no coolant left, again in which case repainting the engine will be the least of your worries
jamesg20
posted on 12/12/06 at 04:55 PM |
Ok cool thanks... next question...
Where can i get paint in spray can form?
I have the paint code from lotus but halfrauds don't have it, I'm trying to avoid having to source it through the main stealer.....
RazMan
posted on 12/12/06 at 05:12 PM |
Your local paint factor will be able to mix it to your paint code and stick it in an aerosol for you - much better paint quality than Halfrauds too.
Raz
the_fbi
posted on 12/12/06 at 05:14 PM |
May be cheaper from a main dealer....
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130058457613
posted on 12/12/06 at 05:15 PM |
Better spray cans too - the paint place I go to makes up cans that give a really good fan pattern, with no spattering. It comes as a surprise when
you're used to cr*ppy Halfrauds and Plasticote cans...
the_fbi
posted on 12/12/06 at 05:17 PM |
Last Halfords cans I used were perfect. Nice steady pressure/fan and did a perfect job.
Cam cover above was with Halford cans. Doing some manufacturing at work currently where we're used Halfords cans too, all perfect.
Best primer/lacquer has to be U-Pol System 20 though (www.bodyshopwarehouse.co.uk)
jamesg20
posted on 12/12/06 at 05:28 PM |
What can I say?!
Thanks very much, paint ordered.
chriscook
posted on 12/12/06 at 06:37 PM |
The paint halfords make up in a spray car for you comes in pretty decent cans - they are different to there on the shelf types cans.
