New Topic New Reply
Author: Subject: Home Made Pinto Exhaust Manifold - again !
swood
posted on 31/12/06 at 03:11 PM Reply With Quote
I tried to post this 4th Dec but failed with the pictures, I have had time to follow the instructions James kindly posted so here goes.
As previously mentioned the Manifold was made the hard way by bending 1.5" x 14g tube on a hydraulic pipe bender.
I made up a jig to duplicate the position of the head and front side rail of my MK chassis because this method needs a straight length tube before the bend.
The exhaust port positions on the jig were clearance on 1.5"so I could pass the pipe through & so get the bends right before cutting them to length.
Manifold was tacked up and tried on the car before final welding by a work mate - I am no welder !!!
Tubes were packed with sand to prevent them collapsing, Rortys site was very handy, but it still took several attempts to perfect the packing techniqe & then to get the bends correct.
The lengths are not the same and there are several uniformed kinks around the bends but its still better than the cast iron original - is'nt it ?.
With hindsight it would have been easier to fabricate it from bends, this method was very time consuming and difficult to achieve the end result, but I had the hydraulic bender and purchased the tube so had to persevere!
Also finished the brake lines over the holiday, fuel tank is next - hurrah !
Exhaust Manifold in Jig
[img][/img]
When you're up to your ass in alligators you tend to forget the initial objective was to drain the swamp !.
Rudy
posted on 31/12/06 at 05:07 PM Reply With Quote
Weel done.
Can you post a pict of your bender?
How did you pack with sand?
Sorry about my English
swood
posted on 1/1/07 at 08:42 PM Reply With Quote
Exhaust Manifold.
Hi Rudy,
I have sent you a U2U
roadrunner
posted on 1/1/07 at 09:02 PM Reply With Quote
Are all your manifold pipes the same length , mine all differed , and it killed top end performance, good job all the same.
macnab
posted on 1/1/07 at 09:14 PM Reply With Quote
I like it but watch for sharp corners on the box where there coming together.
Does anyone know of a diy weld together kit for the 2.8 v6, had a look on the net and drew a blank...
Catpuss
posted on 11/1/07 at 06:41 PM Reply With Quote
Thats a nice piece of work.
With that nice engine colour do you actually need lighting to pass the SVA?
New Topic New Reply
