Author: Subject: Stainless steel tube
scutter
posted on 7/1/07 at 06:17 PM Reply With Quote
I'm attempting to make a modification to my exhaust.
I need to find a piece of 4"(112mm) Dia stainless steel tube with a wall thinkness of between 3/16 and 1/4(4.75 to 6.35mm), it only needs to be 30mm long.
Does anyone know of where i can get or order such a strange size in such a small quantity?
Many thanks in advance, Dan.
nitram38
posted on 7/1/07 at 06:22 PM Reply With Quote
Have you thought of getting a flat strip of stainless, then rolling and welding it?
Most small engineering companies would probably do this for you, rather than buy in a length of pipe and cut it off.
theconrodkid
could you get some strip and bend/weld it?
who cares who wins
pass the pork pies
scutter
posted on 7/1/07 at 06:29 PM Reply With Quote
you know what they say about great minds working together
It did cross my mind, but rolling a perfect circle out of 4-6mm stainless doesn't fill me with joy.
ATB Dan.
nitram38
posted on 7/1/07 at 06:34 PM Reply With Quote
If you get it rolled properly so that the ends overlap, then you can expand it to 4" and cut straight through the overlap. You will then have a perfect circle to weld.
Try this first as it is the easiest and cheapest option.
As for great minds.........I lost mine some time ago !
[Edited on 7/1/2007 by nitram38]
theconrodkid
posted on 7/1/07 at 06:41 PM Reply With Quote
why so thick,building a thermo-nuclear device?
who cares who wins
pass the pork pies
meany
posted on 7/1/07 at 06:53 PM Reply With Quote
have a word with these guys, maybe they can help you out...very friendly.
http://buystainless.co.uk/index.htm
macnab
posted on 7/1/07 at 06:59 PM Reply With Quote
Failing that take a visit to your local scrap metal merchant, that's where I go...
I'll cost you £2 for that
Simon
posted on 7/1/07 at 07:33 PM Reply With Quote
Dan,
I have some 4" stainless, but it's only 2mm thick.
You're more than welcome to it, probably enough to maybe do a couple or three layers if required. Will measure spare tomorrow, as I still have another can to make
Let us know where to send if you're interested.
Simon
rayward
will check at work for you tomorrow.
might have something there
Ray
welderman
posted on 7/1/07 at 08:11 PM Reply With Quote
Ray
Same as above,
Joe
Thank's, Joe
I don't stalk people
scutter
posted on 7/1/07 at 09:20 PM Reply With Quote
John, it needs to be this thick so i can lathe a 1mm step in it then drill and tap it to make the endplate easily removable.
Bad picture time(paint at it's best), the bit I need to get is in the middle, the Blue line mark where it'll be welded to the end plate and the red pegs and circles will be the tapped holes. I hope that's a clear as mud
Image deleted by owner
Thanks to those loooking tomorrow. Dan.
Digger Barnes
posted on 8/1/07 at 12:15 PM Reply With Quote
We use allot of stainless scheduled pipe at work. Having a quick look at the tables, we would definitely have 4" Sch10s 316L which is 114.3mm OD and wall thickness 3.05mm and also the is a possibility we may have sch40s which is 6.02mm wall thickness. If the sizes are OK let me know and I will get you some sorted.
Gareth
