New Topic New Reply
Author: Subject: Cutting steel plate
cloudy
posted on 10/1/07 at 03:10 PM Reply With Quote
Cutting steel plate
I'm needing to start making engine mounts and suspension mounts with 4mm steel, any better way than a hacksaw to cut it?
cheap equipment only, no suggestions of laser or plasma cutters!
James
nitram38
posted on 10/1/07 at 03:11 PM Reply With Quote
Jig saw?
DIY Si
posted on 10/1/07 at 03:15 PM Reply With Quote
It takes a while, but I use a grinder on 3-5mm plate. Mainly because it's the only way I can do it, other than hacksaw. And that'd take forever.
Sun Tzu, The Art of War
flak monkey
Get some 1mm angle grinder cutting discs from Wickes. I have used them loads of times for slicing things up and because they are so thin it doesnt grab too much.
[Edited on 10/1/07 by flak monkey]
Sera
http://www.motosera.com
James
posted on 10/1/07 at 03:26 PM Reply With Quote
Agree with David.
Get the thin discs about 1mm... like a hot knife through butter!
And my mounts for a Pinto (not the lightest engine around) are made of nothing more than 3mm plate and 3mm wall box section.
HTH,
James
cloudy
posted on 10/1/07 at 03:43 PM Reply With Quote
suspected it would come down to my trusty grinder - it's the no1 used tool in my workshop!
James
cloudy
posted on 10/1/07 at 03:44 PM Reply With Quote
hmm on that point maybe i'll try and go 3mm, as i'm trying to keep the weight down after all!
it's only a puny little gsxr i'm mounting
James
Darren S
posted on 10/1/07 at 03:45 PM Reply With Quote
These are superb. They last very well also.
http://www.tyrolit.com/page.cfm?vpath=divisions/metalfabrication/2in1
As you say, like a hot knife through butter. The 125mm dia version will just about fit inside the guard on a 115mm angle grinder.
iank
posted on 10/1/07 at 04:09 PM Reply With Quote
Another vote for the 1mm discs. I used Makita successfully.
macnab
posted on 10/1/07 at 04:20 PM Reply With Quote
angle grinder
cloudy
posted on 10/1/07 at 04:46 PM Reply With Quote
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=25856&ts=47515
these are only 3mm , so you'd recommend sniffing out some ultra thin ones?
Any good high street sources?
James
[Edited on 10/1/07 by cloudy]
cloudy
posted on 10/1/07 at 04:48 PM Reply With Quote
ignore me, found the makita 1mm ones
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A238040&ts=47686&id=60739
posted on 10/1/07 at 05:29 PM Reply With Quote
As previously agreed- grinder discs the way to go. Using a hacksaw will take you months to cut it out, and you'll still need to dress it in all probability.... Use a cutting disc to get roughly to shape then a grinding disc to shape the item.... You can even file it by hand to dress it properly at the end....
hillbillyracer
posted on 10/1/07 at 09:39 PM Reply With Quote
We use them all the time at work, brilliant! I've found the stainless steel ones by Dronco & the same spec by Norton BDX to be best & as little as 60p each.
flak monkey
posted on 10/1/07 at 09:45 PM Reply With Quote
Its not that bad with a hacksaw if you have a good frame and blade. Unless you are one of the many who cant actually cut straight with a hacksaw!
I cut all the bits for my alternator mount out with a hacksaw and thats 10mm plate (dont ask) because i had run out of discs. Good for the shoulder muscles
Sera
NS Dev
posted on 11/1/07 at 08:01 AM Reply With Quote
If its all odd bits then grinder and thin disc.
If you need a few similar bits, draw them up on CAD and get some quotes from subcon laser contractors, you may be surprised at the lowish price!
If they are all one plate thickness it should be pretty cost effective.
Nisseven
posted on 11/1/07 at 10:11 AM Reply With Quote
Yep use the 125 x 1mm cutting discs. I have a second 100mm grinder, one of those cheapies you throw away when the brushes wear out, with a flap disc on it to make nice smooth edges.
Bruce
Alan B
posted on 11/1/07 at 01:04 PM Reply With Quote
Cloudy.....
Could you let me quote the parts?
Living here in Florida will probably make me uncompetitive due to shipping, but I've just built a CNC plasma system and I'd like some real jobs to quote to help me get some practice, and see how I compare on pricing.
Alan
[Edited on 11/1/07 by Alan B]
This applies to anyone...any parts you need cutting or have already been cut I'd love to see and quote...will help me a lot in seeing if I could have a viable business (or sideline at least)
Alan
cloudy
posted on 11/1/07 at 03:35 PM Reply With Quote
OK will do so when ready
wilkingj
posted on 11/1/07 at 09:27 PM Reply With Quote
Angle Grinder and 1mm Discs, they wear fairly quickly, but are brill for neat cutting.
Best Regards
Geoff
http://www.v8viento.co.uk
New Topic New Reply
