New Topic New Reply
Author: Subject: Zetec Installation Costs
posted on 13/1/07 at 01:41 PM Reply With Quote
Looking round our excellent resource here I can't help but feel some people are encountering big costs installing a zetec in their cars.
I did a lot of costing when I was choosing an engine and the zetec was bar far the cheapest option. The parts to convert to rwd where found easily and very cheap!
I would like to know what everyone thinks on this subject.
Less than £500 for me.
DIY Si
posted on 13/1/07 at 01:51 PM Reply With Quote
I think the main cost is getting the engine itself running, as I believe the standard inlet stuff to be to big. Otherwise, it shouldn't be too much. Just need to get the correct/matching flywheel and starter.
Sun Tzu, The Art of War
zzr1100rick2
posted on 13/1/07 at 01:52 PM Reply With Quote
one arm and a leg
but yes around the £500 for engine g/box megasquirt etc
phoenix70
posted on 13/1/07 at 01:55 PM Reply With Quote
so does anyone have a definative guide to fiting a zetec to and seven?
trogdor
posted on 13/1/07 at 01:59 PM Reply With Quote
am hoping to do it for much less than that,
£80 for 1800 XR3i zetec,
£2.20 for whole escort car loom and ford ecu
~£40 for getting modified clutch plate
£?? for engine mounts
£35 for uprated gearbox mounts
As you can prob tell, i am hoping to run the zetec on the standard loom and ecu, its an old 1992 engine and loom and am hoping i can get that sorted
Luckily for me the engine bolts straight up to my saab gearbox and hopefully the starter will too. (altough that is abit of an unknown) ALso the standard inlet stuff can be retained as it will fit under my bonnet.
oh yeah £15 for high pressure fuel pump
so am hoping its only gonna cost around £250 £300 for it all though it will prob be more!!
posted on 13/1/07 at 02:17 PM Reply With Quote
____________________________________
It only cost me £26 for a Mondeo clutch that bolted straight on and works no problem.
The standard ecu may casue some problems as it controls lots of other things too. The immobiliser, door locks and windows if I'm not mistake and if they are not present the ecu will go on strike!
big_wasa
posted on 13/1/07 at 03:36 PM Reply With Quote
Two arms, Two legs, and my sole sold to the boss aswell
Doesnt need to be that dear.
Can be done for £500 and less with out the exhaust but its easy to get carried away and get lots of nice fabricated bits ect.
The exhaust I think is one of the dearer parts for the conversion.
Every body installs them in a differant way so there can never be a definative answer. If you have the tools and can use them then the cost will be cheaper and your input longer
posted on 13/1/07 at 03:59 PM Reply With Quote
This all makes me happier about staying with my crossflow!
(but I do understand that it would be a better engine when finally installed)
andybod
posted on 13/1/07 at 06:56 PM Reply With Quote
engine £100
escort sump £25
clutch £75
alt brackets £80
water pump £30
service items
inc timing belt £35
manifold £75
dellortos £325
weber ecu s.h £300
exhaust £350
£1395
bugger should have gone bec
TangoMan
posted on 13/1/07 at 07:18 PM Reply With Quote
I think I have got all the bits I need now and mine will stand me around £1000.
This will include
2.0 Zetec with
Lightweight flywheel and pinto clutch
Innovate LC1 Wideband Sensor
Megasquirt
GSXR750 TB's
Silicon Hoses
Made my own manifolds (although bought the flanges, bends and tube)
CVH sump, modified for ground clearance.
New cambelt and service items
All hose, clips, connectors etc.
It's more than I expected it to cost but I have got all the right bits as I intend to sort the head and cams next winter
It could be done a lot cheaper with carbs or standard injection and cast exhaust manifold.
Summer's here!!!!
posted on 13/1/07 at 07:20 PM Reply With Quote
That's interesting, in fact it's amazing. Did Saab have any Ford input back when they were making RWD cars?
Is the box from an older 900?
andybod
posted on 13/1/07 at 07:53 PM Reply With Quote
didn't the saab 96 use the ford v4
DIY Si
posted on 13/1/07 at 08:01 PM Reply With Quote
I think so, as IIRC that's what he pulled out to fit the zetec.
Mansfield
posted on 13/1/07 at 08:37 PM Reply With Quote
My nearly new Westfield CVH exhaust manifold cost me £75. Apparently these can be made to fit a Zetec due to similar port spacing and some holes matching up. Bit of work required but a big saving on new.
posted on 13/1/07 at 08:48 PM Reply With Quote
I got two 1.8 XR2i engines for £27. I bought one on ebay and when I got there he had two and wanted the garage cleared as he was flitting.
bob
posted on 14/1/07 at 12:16 AM Reply With Quote
This probaly the best and longest thread on the zetec insatls,plenty of variation and parts info.
zetec guide link
trogdor
posted on 16/1/07 at 12:21 PM Reply With Quote
yep saab used a ford v4 engine, not the one fitted to transits etc but a german one, they look very similar but very few parts will interchange, its also better apparently but i wanted to change it as it costs loads to uprate
the zetec will bolt on using four bolts on the bellhousing., however there are probs with the clutch as the spline pattern is different from saab to zetech so am abit unsure how to get the zetec clutch on the gearbox!
just thought i would add, saab have never made a RWD car, the 96 has a transaxle type of gearbox complete with freewheel and column shift!
[Edited on 16/1/07 by trogdor]
DIY Si
posted on 17/1/07 at 12:00 AM Reply With Quote
The clutch plate needs to match the gearbox, and if poss use one that matches the flywheel. Other option is to use the matching plate, and get a flywheel made, or re-drill one to suit the crank.
trogdor
posted on 17/1/07 at 09:40 AM Reply With Quote
hmmmm this is going to be more difficult than i thought, the saab clutch will fit the gearbox, but prob not the flywheel, how can you tell if they are compatable? the front cover of the clutch from the V4 won't bolt up to the zetec flywheel, though i could get it modified so it could.
Is annoying as the saab and zetec flywheels are very similar, only difference is the way they are bolted to the crank!
am not sure where to go with this, ideally spending as little money as poss!
Schrodinger
posted on 17/1/07 at 11:11 AM Reply With Quote
You could try the Zetec clutch cover with a Saab friction plate.
I had a 2.0l Zetec flywheel lightened, balanced and machined by Scholar to take a Pinto clutch for about £100 IIRC.
So there should be no reason the same flywheel should not be machined to take the Saab clutch although you will need to find a spigot bearing to fit both the gearbox shaft and the Zetec but that shouldn't be too much of a problem as it is likely that the one used with a Type 9 box will fit.
[Edited on 17/1/07 by Schrodinger]
jamesg20
posted on 18/1/07 at 08:24 PM Reply With Quote
You do need to allow for a modified sump when running the zetec inline. None of the standard ford sumps are up to it. If you don't get the sump baffled properly you won't last very long..
trogdor
posted on 19/1/07 at 09:10 AM Reply With Quote
well i have sorted my friction plate prob, have found a company who can modify the zetec clutch to fit the saab input shaft
now my prob is the clutch release bearing, need to get it modified to have a bearing with a rounded face not a flat one like the 96's
i have heard about the sumps before, but i have also read that you can get away with a 1800 sump which is what i have so i will see how long it lasts! i am not going to ragging this car around a track so i think it will be ok
Memphis Twin
posted on 20/1/07 at 11:09 AM Reply With Quote
Are you sure theZetec will bolt onto the Saab gearbox? The V4 was basically 2/3 of the Cologne V6, but I thought that this had a different bellhousing bolt pattern.
I have had several 96s in my time (learnt to drive and took test in one) but I never knew the Ford inline engines would bolt on. Problem is the gearbox is very weak, and struggles with the V4's 65bhp so I don't know how it will cope with 150+.
I once had the hair-brained idea of converting my 96 to RWD using a XFlow and escort axle - never came to anything but I'd still like to do it one day
Cheers Chris.
trogdor
posted on 22/1/07 at 09:17 AM Reply With Quote
yep the zetec will fit, i have had the v4 out and have offered it up, the top two bolts dont line up with the bellhousing, but the next 4 holes do and since there are only 4 bolts holding it on this should be ok, the engine bay does need modding tho, the valence and strut brace need to modified
yeah alot of people are telling me that the gearbox is weak and will fail but then there are alot of people who say its not as bad as all that, rally saabs used to have nearly 200bhp and they weren't signifcantly different!
my plan is just be gentle with the car, ie don't drop the clutch at 4000 rpm! see how long it lasts and get a decent rebuild and see if that lasts ok if not will have to fit another transaxle, audi or similar but that is way off in the distance!
New Topic New Reply
