Author: Subject: Essex v6
jacko
posted on 15/1/07 at 08:01 PM Reply With Quote
Essex v6
Hi all will a type 9 gearbox fit a ford essex v6 3000cc
jacko
PAUL FISHER
posted on 15/1/07 at 09:21 PM Reply With Quote
Your taking the York drag day a bit too serious Graham
TL
posted on 15/1/07 at 09:30 PM Reply With Quote
No, not unless you happen to have the bellhousing from a 2.5litre consul/granada.
These are like rocking horse pooh.
The 3litre used a beefier gearbox than the 2.5litre, with a unique B/H to box hole pattern.
The 2.5 used the smaller gearbox (bullet? 2000e?), which the type 9 was based on, so the 2.5 B/H will fit the type 9 and the back of the Essex. If you are lucky enough to be the only person on the planet with a spare 2.5 B/H, then you need to use the V6 type 9, and cut the first ½" or so of the input shaft.
All the gearboxes are "type something-or-other". I can't recall which one is which, but the burtons site has all the good info.
HTH
[Edited on 15/1/07 by TL]
Terry
mcerd1
posted on 15/1/07 at 10:46 PM Reply With Quote
not a type 5 by any chance?
https://www.burtonpower.com/technical/tt_type5.html
I think thats whats on my scimitar (but I could be wrong)
TL
posted on 19/1/07 at 12:52 PM Reply With Quote
That's the kiddy.
I think the earlier Scimitars were fitted with the box in the photo, but later ones (like my SE6A) had external linkages, but the guts of the box are similar, and I suppose the 3litre bellhousing fits both types (i.e. both internal & external linkage types)
Terry
mcerd1
posted on 19/1/07 at 04:16 PM Reply With Quote
There is a pic of the other one too somewhere on burtons site I think ?
anyway if you can use the bits form these then there are plenty scrap scimitars and capris about still
jacko
posted on 19/1/07 at 07:43 PM Reply With Quote
Thankyou for the info in that case a v6 box will fit a 20l pinto ?
Jacko
24vseven
posted on 19/1/07 at 08:22 PM Reply With Quote
not quite you need a pinto bellhouseing i have i could sell if you need it
they are a 4 bolt swap easy job or if you have the cash you could scorce an rs2000 alloy bellhouseing for them
jacko
posted on 19/1/07 at 08:44 PM Reply With Quote
Thanks i have a bell housing
Jacko
