kikiturbo
posted on 18/1/07 at 04:01 PM |
CXR wheels dimensions
Hello,
may I kindly ask someone with 13 inch CXR's to measure the inside diameter of the wheels, if it's not too much trouble...
I want to buy a set and need to see what exactly I can fit in with regards to brakes, before I send the final brake clearence sheet to compomotive for
approval, as compomotive will not send out cross sectional drawings...
best regards
vlado
Coose
posted on 20/1/07 at 04:47 PM |
I had a measure of one of my front CXRs (13x6" and it looks like 300mm would give you clearance. Do please bear in mind that this is an
approximate measurement as I didn't have the chance to take the wheel off the car, plus I couldn't find any of my many tape measures and
all I had to hand was a steel rule.
Hope this helps!
Spin 'er off Well...
kikiturbo
posted on 21/1/07 at 08:39 PM |
thx a lot...
300 mm sounds like a good conservative measurement, although I was hoping for more as some wheels I got the cross section for (as Dynamag's etc)
were more like 310 mm inside... although CXR loks like best value for money...
I will have a go doing the final upright design with 300 mm, I might adjust later....
cheers
vlado
Coose
posted on 21/1/07 at 08:57 PM |
It could easily be as much as 320mm, though as I said I was limited by time and measuring devices to hand.....
