Author: Subject: attach photos
Bouldy
posted on 26/1/07 at 02:34 PM Reply With Quote
attach photos
Bouldy
posted on 26/1/07 at 02:35 PM Reply With Quote
what i meant was. How do i condence a photo so i can attach to the forum. I have tried but it saying file to big
Paul
macnab
posted on 26/1/07 at 02:40 PM Reply With Quote
use something like paint shop to reduce the size to about 700 pixels wide.
JPEG or GIF are best formats to use.
[Edited on 26/1/07 by macnab]
Bouldy
posted on 26/1/07 at 02:45 PM Reply With Quote
Tried that just cuts half the photo off
There is away of doing it cant bloody remember...
donut
posted on 26/1/07 at 02:47 PM Reply With Quote
You need a programme like photoshop that will reduce the dpi without reducing the physical size of the image.
macnab
posted on 26/1/07 at 02:51 PM Reply With Quote
check the tick boxes sounds like its not scaling all layers
Bouldy
posted on 26/1/07 at 02:58 PM Reply With Quote
Just had againo again still no joy. all tick boxes were ticked reduced to 700 and it cuts half the pic off.
Bloody thing will be going through the window in a min !!!! grrrrrrrr
Somone will have to explain in 'twat form' cause im not that up in computers or the jargon which computer folk talk in
ecosse
posted on 26/1/07 at 03:02 PM Reply With Quote
You want to "resize" rather than change the res
Alex
bbwales
posted on 26/1/07 at 03:03 PM Reply With Quote
If you go to google and type in microsoft power tools, you will get a samll programme where all you need to do is rught clip on the photo and it asks you how much do you want to shrink the pic by, very easy and free.
Bob
cossiebri
posted on 26/1/07 at 03:07 PM Reply With Quote
bbwales,you beat me to it.
I use this prog after reading it on somewhere,very easy to use
If it doesn't fit MODIFY it!!
Cheers BriF
roadrunner
posted on 26/1/07 at 03:14 PM Reply With Quote
I just resize mine in the edit list, 50% each way works a treat.
ricklawn
posted on 26/1/07 at 03:19 PM Reply With Quote
put picture in microsoft paint, press image then stretch/skew and just reduce by 50%
macnab
posted on 26/1/07 at 03:40 PM Reply With Quote
hmm I'm stuck with that program at work, no paintshop. It insists in saving even a JPEG as a BMP image, pest it makes utter mess of the image reducing the number off colours!
RazMan
posted on 26/1/07 at 05:50 PM Reply With Quote
Or you can use PIXresizer from here
Raz
Johnmor
posted on 26/1/07 at 08:20 PM Reply With Quote
Adobe
In adobe photo or windows picture viewer
Simply right click on the photo in the file and select "resize pictures" or if the photo is open Right click and select "resize picture"
It gives several options along with their resolution.
It will then be saved as a copy but of the selected size.
Small -is suitable for your Avatar
Medium- for posting with comments
Hope that helps
