Author: Subject: Transferring template to metal
vintagebuilder
posted on 31/1/07 at 05:28 PM Reply With Quote
Evening All,
I'm wanting to make a pair of windscreen uprights and have been given a template traced on brown paper. Could anyone plese advise how to transfer the shape onto the material I'll be using for the uprights?.
Regards
posted on 31/1/07 at 05:40 PM Reply With Quote
You could tape the template to the metal, then make dots with a punch at all the significant points. Take off the template and join the dots!
Confused but excited.
posted on 31/1/07 at 05:51 PM Reply With Quote
Or use carbon paper.
YES, I know I'm old but you can still buy it.
jolson
posted on 31/1/07 at 06:44 PM Reply With Quote
I use spray mount. It's available at any decent art supplis shop, about £7/spray tin.
It doesn't go off right away, so you can adjust the pattern on the metal. It holds well enough for an angle grinder to do it's job, but a jiogsaw will sometimes lift the edge slightly. The easiest way to remove it is with a bit of heat; a hot air gun works well.
It works a lot better than tape because the pattern is held down over it's entire surface.
John
owelly
posted on 31/1/07 at 06:53 PM Reply With Quote
Another vote for using the dot punch!!
I either tape the template to the metal or wet it a bit so it clags to the metal, then dot through the paper as often as you need to get a good shape.
http://www.ppcmag.co.uk
posted on 31/1/07 at 07:18 PM Reply With Quote
Double sided sticky tape. You can get nice wide stuff from B+Q... Comes off nice and easily afterwards and doesn't lift if you use a jigsaw on the metal...
907
posted on 31/1/07 at 07:58 PM Reply With Quote
Run the drawing through the photo copier and make a couple of copies.
If they are bigger than A4, do it in two and tape together.
You can then keep the original and use the dot punch on the copies.
The sprung loaded dot markers are useful tools for this sort of thing.
Paul G
posted on 31/1/07 at 10:09 PM Reply With Quote
Copy the drawing then cut out the copies stick on to surface and mist spray with aerosol paint then peel off.
vintagebuilder
posted on 1/2/07 at 07:54 PM Reply With Quote
Evening All,
Thanks for all the advice.
Regards
rebelrider
posted on 1/2/07 at 10:57 PM Reply With Quote
send me the template ill scan it and laser cut them for you hows that for an idea lol im feeling charitable tonight
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 2/2/07 at 05:15 AM Reply With Quote
Cut out the template, stick it on with tape and draw around it with a fine permanent OHP pen.
I used to use the centre punch method but it takes ages.
John
