New Topic New Reply
Author: Subject: tube bender
moss
posted on 3/2/07 at 12:29 AM Reply With Quote
tube bender
Tube bender die set for sale I have two left £130 each to bend1 ½ inch tube with a 5 ½ inch C L R die will be steel
I’m having 6 sets made at £130 each 4 have been sold. This is the cheapest way to get a tube bender. Once these are sold may look at having other sizes made
I well also include a set of plans build a bender like this one
bugtub@hotmail.com
tube bender
[Edited on 3/2/07 by moss]
froggy
posted on 3/2/07 at 12:42 AM Reply With Quote
do you have any pics as i have a tube bender that does up to 1 1/4 but would take an 1 1/2 die if it is a 180 degree one
moss
posted on 3/2/07 at 12:58 AM Reply With Quote
Don’t have any pictures of die set yet as there are still being made but I can say now they will be 120 degrees
froggy
posted on 3/2/07 at 01:11 AM Reply With Quote
defo up for one if ytou can sort a pic giving sizes and the bore of the pivot hole
moss
posted on 3/2/07 at 01:36 AM Reply With Quote
Having real trouble trying to post pictures.
Will be making 3 die out of one blank boring an oversize hole in the centre hence can only be 120* then will make a bush to be wielded in the centre for the pivot hole. This hole can be what ever size you like.
Hope this makes sense
moss
posted on 3/2/07 at 01:51 AM Reply With Quote
http://groups.msn.com/wwwbeachbuggyorguk/forsalewanted.msnw?action=get_message&mview=0&ID_Message=27745&LastModified=46756083860443791 03
Johnmor
posted on 3/2/07 at 06:59 AM Reply With Quote
What about this.
Is this the same idea?
swood
posted on 3/2/07 at 09:40 AM Reply With Quote
What About This
This will not work on thinner tube.
Its a pipe bender, and the tube wall will collapse and kink.
Also the formers supplied will not be a snug fit around tube.
The difference between pipe & tube is as follows, the notional size on pipe refers to the inside diameter, with tube its the outside diameter.
The tube bender actualy pulls the tube around the former via a guide which prevents it collapsing.
The pie bender deforms the static pipe by pushing the former into the pipe.
I wish I had seen the a forementioned tube bender because although I succeded in making my exhaust from tube on a pipe bender it was a huge amount of work, I had to machine one of the formers to fit the tube - not easy even though I have access to some basic machines.
The tubes had to be very tightly packed with sand, I finally achieved by blanking the ends, and compressing via a 'piston' & M12 bolt.
Look at Rorty's site for info on pipe & tube - its excellent
When you're up to your ass in alligators you tend to forget the initial objective was to drain the swamp !.
moss
posted on 3/2/07 at 12:53 PM Reply With Quote
[Edited on 4/2/07 by moss]
moss
posted on 4/2/07 at 01:12 AM Reply With Quote
gazza285
posted on 4/2/07 at 04:11 AM Reply With Quote
Originally posted by swood
.........The pie bender..........
Made me laugh.
swood
posted on 4/2/07 at 09:45 AM Reply With Quote
Pie bender !
Always having trouble wiv me worms, that smell checker don't pic fing like that up do itt.
New Topic New Reply
