Author: Subject: chain needed for engine hoist
jimbona2
posted on 22/2/07 at 05:05 PM Reply With Quote
hi everyone
has anyone got a chain that I can borrow this weekend for hoisting my engine? how much to borrow it etc..? I live in cambridgeshire..
thanks
marshall
posted on 22/2/07 at 05:12 PM Reply With Quote
i used some tow rope and it did the job
or you could use a old seat belt. its up to you .
westcost1
posted on 22/2/07 at 05:28 PM Reply With Quote
I used an orange ratchet strap for holding things on roof racks raped round a few times worked a treat but seat belt would be just as good.
jimbona2
posted on 22/2/07 at 05:37 PM Reply With Quote
thanks unfortunately the roof within the garage hasnt got any poles to hoist on otherwise that would be ideal, hence looking for some chains as i've got an engine hoist.
zxrlocost
posted on 22/2/07 at 05:47 PM Reply With Quote
seat belts work just as good and a simple knot here and there
Bluemoon
posted on 22/2/07 at 05:48 PM Reply With Quote
Wicks sell chain that's rated to 200kg...
Dan
wilkingj
posted on 22/2/07 at 06:52 PM Reply With Quote
Mackays on East Road in Cambridge sell Chain in any length from two links upwards. If its just for lifting the engine, the 6mm or 8mm chain is good. Its what I used, and its not expensive.
I use some cheap shackles and old car seat belts. as well. They are on the other wall near the chain as you go in the back doors from their carpark in New St.
Seat belts were recovered from the scrap yard
Best Regards
Geoff
http://www.v8viento.co.uk
snapper
posted on 22/2/07 at 09:45 PM Reply With Quote
u have u2u, I use those loose nylon bag strops, got them from ebay for a few quid and have used them lots of times on the hoist, they are also a bit kinder on the shiny bits
I eat to survive
I drink to forget
Angel Acevedo
posted on 23/2/07 at 11:04 PM Reply With Quote
Used a 1-1/4" nylon strap from a ratcheting Cargo strap, knotted the ends with a toggled bend to make a continuous sling, (you may need to thread through lifting eyes before the knot) then pass through crane hook, this way you have sling rating times 4 (slightly reduced due to angle)
Just make sure you have your CG centered, so the motor does not shift.
tractorboy
posted on 2/3/07 at 07:04 PM Reply With Quote
hello mate , i have one in burwell if its any use and you still need one . scott
