Author: Subject: Removing Mondeo engine.
zetec
posted on 11/3/07 at 06:36 PM Reply With Quote
What's the easiest way to extract a Mondeo engine...just engine or engine and gearbox then split...?
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
bob
posted on 11/3/07 at 06:39 PM Reply With Quote
Hello kevin
If your not keeping the car/body
I took the 1800 zetec i have put in the indy out of an escort estate by taking a 9" cutting disc to the front and driveshafts unbolted and unplugged it then pulled it out eng and box on a trolley.
[Edited on 11/3/07 by bob]
Werner Van Loock
posted on 11/3/07 at 06:42 PM Reply With Quote
Easiest is to drop the whole subframe/engine/gearbox combo from underneath the car if you have the possibility to lift the car.
Otherwise you'll need to strip the engine from everything that's connected to it to get it out the top.
http://www.clubstylus.be
theconrodkid
posted on 11/3/07 at 07:15 PM Reply With Quote
what bob said
who cares who wins
pass the pork pies
zetec
posted on 11/3/07 at 07:22 PM Reply With Quote
I say chaps all a bit drastic! I'll have another look tomorrow at those options, still need to be able to move the car once removed...and still be talking to the neighbours!
Danozeman
posted on 11/3/07 at 07:29 PM Reply With Quote
The easiest way is cut the front out and drag it out the front. Failing that drop the subframe off the bottom with the engine and box still on it. Lift the car over it all.
Dan
posted on 11/3/07 at 07:35 PM Reply With Quote
Ford install the engine complete on the sub frame with two people in around 10 seconds.
Get underneath and undo the sub frame bolts, disconnect all the bits and pieces, wiring, gear change exhaust etc. On top undo the top mounts for the suspension uprights and lift the car off. The whole lot should come out in one go with front suspension, hubs, brakes and even the radiator on the sub frame.
IMHO the easiest way to do it, in reverse of the way Ford put it in
snippy
posted on 11/3/07 at 07:42 PM Reply With Quote
You can actually remove the Zetec from a Mondeo without undoing the subframe at all. The photo below proves it. I removed this 2.0 Zetec by hoisting it out upwards leaving the car on all 4 wheels and gearbox still in! I just left one gearbox mounting attached so as the engine was lifted upwards at an angle, the gearbox slanted upwards in order to seperate the engine from the gearbox. I then wheeled the car back out of my garage.
Nick
ProjectX
posted on 11/3/07 at 09:05 PM Reply With Quote
Thats what I did. On my own, half a dozen sockets and two ramps. Job done! Bolted the sub frame back in and wheeled the mondeo back into the neighbours garage!
HTH J
oliwb
posted on 11/3/07 at 09:42 PM Reply With Quote
Thats how I did it in a scrapyard too! Though in hind sight and if I were to do it again I'd borrow a stihl saw from someone and cut the drivers wing in front of the bulkhead and at the bumper and effectivly removing the whole arch. That would make it a simple job of unbolting and jiggling! Oli.
