Author: Subject: Hand-operated vs. Pedal clutch cylinder
xico_ze54
posted on 12/3/07 at 12:01 PM Reply With Quote
when changing the hand-operated clutch master cylinder from a bike to pedal operated in a car, wich is the ideal bore of the master cylinder to be used? the engine in focus is a '94 CBR1000.
cheers
Amadeu
posted on 12/3/07 at 12:37 PM Reply With Quote
If you've got the hand-operated set-up why not keep it? Replace the squeeze grip with a lever arm and attach to clutch pedal....
xico_ze54
posted on 12/3/07 at 01:13 PM Reply With Quote
in my case I have not the hand operated set up. so I get to find some way to put on a new master cylinder, but wich size?
xico_ze54
posted on 12/3/07 at 01:45 PM Reply With Quote
Originally posted by CaLviNx
Hi
another way round it could be to use a standard single outlet clutch master cylinder & a mini slave cylinder and take out the bike slave cylinder and put in the mini one and play with the ratios to get the pedal "feel" and throw to what you want it to be.
the problem still is: wich bore?
for brakes I intend to use 0.75 & 0.65 from Willwood (as I used in my first Locost), but for clutch I've no idea.
G.Man
posted on 12/3/07 at 01:51 PM Reply With Quote
Or you could keep a hand operated clutch
Opinions are like backsides..
xico_ze54
posted on 12/3/07 at 02:08 PM Reply With Quote
look some posts above: I haven't that piece.
OX
posted on 12/3/07 at 02:11 PM Reply With Quote
you could use any rear brake master cylinder off a honda ,yamaha ,triumph or suzuki
G.Man
posted on 12/3/07 at 02:30 PM Reply With Quote
Yes but if you are buying parts anyway, then what does it matter?
xico_ze54
posted on 12/3/07 at 03:43 PM Reply With Quote
thanks all for solutions presented, but for me its easier to pick a master cylinder near the range of the brake ones, for instance a Willwood model.
it's hard for me look arround for motorcycle salvages. In the end the time spent doesn't pay off.
It's more pratical for me buy three new cylinders, 2 for the brakes and 1 for the clutch.
bennjamin
posted on 22/6/16 at 10:10 PM Reply With Quote
Bumping this one up
Looking and reusing the hand clutch off a salvaged bike - and hopefully some sort of quickshifter -
Something I haven't worked out is this - is driving a BEC like riding a motorbike in that you use the clutch for idle , low speed manouvering and can shift clutch less the rest ?
In my mind a hand clutch seems silly and dangerous for everything above 1st gear ?
40inches
posted on 23/6/16 at 02:29 PM Reply With Quote
Originally posted by bennjamin
Bumping this one up
I think the premise was to use the hand cylinder for the foot clutch pedal.
Clutchless up change ok with practise, clutch for down changes.
