RazMan
| posted on 22/3/07 at 12:05 PM |
Electric Handbrakes
I'm thinking about a future project and if I could design in an electrically operated handbrake it would save a lot of messing about.
iirc the SVA manual doesn't really specify the method of handbrake activation, but I can't see why a stepper motor pulling a caliper (with
a ratchet of some sort) cant be used. Someone mentioned that the Ford C-max has already incorporated something similar but I have yet to find any info
on this.
Has anyone got any ideas or comments?
Raz
balidey
| posted on 22/3/07 at 12:11 PM |
Lots of the new renault have them. Takes a while to get used to.
scottc
| posted on 22/3/07 at 12:13 PM |
Someone on here has done this pre-SVA and it passed SVA. Can't remember who it was though.
here
[Edited on 22/3/07 by scottc]
speedyxjs
| posted on 22/3/07 at 12:15 PM |
All new jags have them too!
RazMan
| posted on 22/3/07 at 12:41 PM |
CaLviNx - Ahhhh I remember the thread now. That linear motor looks ideal - have you got any info on it?
Raz
RazMan
| posted on 22/3/07 at 03:11 PM |
Sorry, I meant a manufacturer or supplier Had a look on eBay and havent found anything yet.
Raz
| posted on 22/3/07 at 03:28 PM |
hmmmm, so if you break down due to battery failure and need to stop, this is when you need the handbrake the most, wotcha gonna do?
RazMan
| posted on 22/3/07 at 04:06 PM |
Chuck a brick under the wheel?
I admit that my plan is slightly flawed but I'm looking at a solution (not the brick)
The ideal gizmo is called a Linear Actuator which will pull 1200N which should be enough for most applications. I am hoping to use the existing
Sierra handbrake setup and retro fit the actuator in the service tunnel (more or less in the orginal handbrake lever position) A three way rocker will
be the ideal switch as it has a lower profile for SVA.
[Edited on 22-3-07 by RazMan]
Raz
DaveFJ
| posted on 22/3/07 at 04:47 PM |
I thought that was the exact reason why hydraulic handbrakes were not allowed. I'm amazed that these are legal!
Dave
| posted on 22/3/07 at 04:50 PM |
Use the footbrake
If you have an electrical handbrake does it need a failsafe device? Do you have the current applying the brake or a spring applying the brake and the
current holding it off like an air brake type system?
[Edited on 22/3/07 by Peteff]
RazMan
| posted on 22/3/07 at 05:15 PM |
The system is basically a stepper motor and a worm drive. You throw a switch to 'pull' the brake cable (or lever etc) and the nature of
the gearbox prevents rotation until a reverse voltage is applied to the motor when the cable is released.
Hydraulic brakes depend on the same circuit as the main braking system so that is a no-no for sva and mot, however I don't see any reason why
you can't have a secondary hydraulic caliper mounted on the same disc - it might not be cost effective though.
Raz
RazMan
| posted on 22/3/07 at 06:35 PM |
I doubt that a seat motor would have the oomph to pull on a handbrake, but I suppose with a long enough throw anything is possible. I have found a
couple of suppliers for the high strength actuators. This one seems the best so far and less than £80 too.
http://www.hiwinactuators.co.uk/linear_actuators.html
Raz
gttman
| posted on 22/3/07 at 07:28 PM |
Already? I havn't even been for a ride in you Aeon yet!
Andygtt
Please redefine your limits
RazMan
| posted on 22/3/07 at 10:27 PM |
You may find the actuating time will suffer as a result of the gearing but it is certainly worth a try. The ones I have found operate at 25mm per
second and I estimate that the cable will need to have around 20mm travel, so less than a second to fully actuate the handbrake.
Andy, Hi mate - this is not for my car It is a hush hush project which MIGHT happen soon. I will divulge all in due course. Are you still in SA?
Raz
