Author: Subject: It rolls at last
v8kid
posted on 27/3/07 at 05:17 PM Reply With Quote
It rolls at last
But only just, clutch wont disengage and rear brakes impossible to bleed.
Still on target at 509kg wet (another 20kg to be added yet) and 34/66 f/r weight distribution. Cof g is only 290mm so I'm well pleased.
Ah well engine out this weekend again and a curse on ap multiplate clutches
v8kid
posted on 27/3/07 at 05:18 PM Reply With Quote
Rats what happened to the picture? I'm sure I attached it is there a trick to it?
v8kid
posted on 27/3/07 at 05:29 PM Reply With Quote
Gave up and put pictures in archive but they are huge - must be missine summat here!
worX
posted on 27/3/07 at 05:30 PM Reply With Quote
think it's prob cos of the size!
download "pixresizer"
First sight of daylight
[Edited on 27/3/07 by worX]
thomas4age
posted on 27/3/07 at 05:31 PM Reply With Quote
DO NOT tell me that's a riot with a Rover V8 in there....
(is it an extended chassis or the normal riot one?)
if so. Brilliant!!!
the 1uz lexus is even lighter than the rover, hhhmmmm
and on a UN1 tranny also?
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
Paul (Notts)
posted on 27/3/07 at 05:35 PM Reply With Quote
worX
posted on 27/3/07 at 05:36 PM Reply With Quote
just a tweek here and there
24vseven
posted on 27/3/07 at 05:38 PM Reply With Quote
looks well
well done
v8kid
posted on 27/3/07 at 05:41 PM Reply With Quote
Yes its an early riot with Un1 box turned upside down and the gearchanhe through the middle of the V. Cant get the photo's to resize though my PC admin is blocking it I'll have to try at home.
I did widen the track and beef up the rear suspension otherwise its fairly standard but the engine had to have major surgery to fit.
v8kid
posted on 27/3/07 at 05:42 PM Reply With Quote
Thanks steve
worX
posted on 27/3/07 at 05:53 PM Reply With Quote
Originally posted by v8kid
Thanks steve
no probs mate - you have to right click and properties the pic in your archive and copy the address (URL) and paste that into the image button thingy whilst writing your post
I had no idea when I started - people on here told me!
cheers,
thomas4age
posted on 27/3/07 at 06:25 PM Reply With Quote
He v8kid,
what was concerned in the surgery.
your engine must be pretty low mount with the UN1 upside down, the sump level is the same as the un1's bottom when it's upright mounted. yours is what, 8cm lower than that?
still brilliant project, I've played with the idea a long time ago.... and though I couldn;t be done. so errhm Well done!
grtz Thomas
v8kid
posted on 28/3/07 at 10:53 AM Reply With Quote
So my cover is blown!!
Sump is close to deck and dry sump is planned. Big chunk was cut off bottom(top) of UN1 box and smaller dia flywheel fitted. More than 40mm at present which is all that matters
Cheers from sunny Stewarton
v8kid
posted on 28/3/07 at 04:50 PM Reply With Quote
Ha! Of course I remember the car still 2 months away from competing due to outside interferences - something about an offspring getting hitched and me having to be there I believe.
Nice car what happened to it?
MrFluffy
posted on 2/4/07 at 12:52 PM Reply With Quote
Lovely, all my fav bits too...
Simon S
Contributor
Posts 20
Registered 18/2/06
Member Is Offline
Photo Archive Go!
Building: Own designed single seat track day car
posted on 11/5/07 at 06:36 PM Reply With Quote
Inverted UN1 & reversing the gear shift
This will teach me not to check all the forums! I am planning to invert a UN1 and have been stretching the grey matter recently to figure out how to deal with the reversed gear shift pattern. Have you done anything about it or just ignored it? More pix of the shift mechanism would be appreciated.
Asennad
posted on 13/5/07 at 05:51 PM Reply With Quote
That’s a mighty fine looking car.
Forgive my ignorance but what exactly is it? Got a link to the manufacturer?
MartinDB
posted on 13/5/07 at 08:59 PM Reply With Quote
It's a Sylva Riot .
Martin.
