Mazler
posted on 28/3/07 at 01:34 PM |
engine/transmission
Has anyone ever mated a subaru boxer engine to a toyota or other 5 speed transmission?
Info please.
Thank you
Mr Whippy
posted on 28/3/07 at 02:04 PM |
oh how I'd love one of these in my beachbuggy I'd pull wheelies like Herbie
bigbravedave
posted on 28/3/07 at 03:47 PM |
You do see the occasional subaru in just rear wheel drive guise in the drifting series, Im not sure if they weld up the center diff and lose the front
prop or use an alternative transmission.
goodall
posted on 28/3/07 at 06:14 PM |
weld up the center diff and plug wear the drive shaft would normally come out for the front wheels and remove the front diff to lose that extra bit of
weight, would that not be the simplest thing to do and you could even go for 6-speed
Mazler
posted on 28/3/07 at 06:52 PM |
Yes... that is what i will be investigating more thoroughly.
Mazler
posted on 28/3/07 at 08:38 PM |
Parts are already being done. You will find them here:
http://www.kingpinperformance.com/
http://rocketrally.com/managed/mod-CMpro-viewpage-pageid-90.phtml
http://www.mrtrally.com.au/forums/topic.asp?ARCHIVE=true&TOPIC_ID=19306
iank
posted on 28/3/07 at 08:58 PM |
An idea so good Bruce Mayers (original inventor of the beach buggy) is using them for his new DualSport buggies.
http://www.meyersmanx.com/manxter-ds.shtml
Uses the turbo and a 18inch straight pipe as the only silencer if the pictures are to be believed.
Anonymous
posted on 28/3/07 at 09:07 PM |
most subarus (impreza and legacy at least) dont have a front prop and diff, they just have a pair of halfshafts straight out of the gearbox, with an
internal diff.
locost_bryan
posted on 30/3/07 at 04:31 AM |
internal diff.
yep, that's what you both said!
It's pretty much the old fwd box, with a centre diff and rear output shaft added.
Middies lock the centre diff and remove the rear output shaft, fronties take out the front diff and driveshafts (and possibly the centre diff?)
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
