Julian B
posted on 28/3/07 at 04:51 PM |
Seeping leaky core Plug
Hi all
I have had my car on the road for all of 200miles now and i have found a problem with water retention. It dosn't, is the problem
I have located the problem to a seeping and leaky core plug.
Having never changed one of these any advice on how to do so would be very welcome... Its an Ali rover V8 lump by the way.
mookaloid
posted on 28/3/07 at 06:36 PM |
Core plug replacement:
1. buy a set of core plugs for your engine
2. remove old core plugs by using punch and hammer to make hole in old core plug and lever out.
3. clean hole
4.after applying suitable sealer of preference drift new core plug in using a suitable sized socket and hammer
5. wipe off excess sealant
Mark
posted on 28/3/07 at 06:47 PM |
Addendum:
Tap each core plug on one side using a drift, so that it spins. This makes removal so much easier!
Also, as Mark suggests, if one core plug has gone, it's a fair bet that they've all gone (or will go soon). Safest option is to change
all of them, rather than have an unexpected major leak.
HTH,
mookaloid
posted on 28/3/07 at 07:11 PM |
quote: Originally posted by David Jenkins
Addendum:
HTH,
Sorry missed point 6. repeat for all other plugs
Julian B
posted on 28/3/07 at 08:15 PM |
Thanks Guys
good info, but what sealant? blue hermatite?
Thanks again
iank
posted on 28/3/07 at 09:07 PM |
As above, it's not uncommon in engines that have sat unused for a while.
Blue Hylomar will do just fine as a sealant. (never heard of hermatite, sounds like a rock )
Edit: did some googling. Hermatite sounds fine as well (still sounds like a rock though )
[Edited on 28/3/07 by iank]
Anonymous
DIY Si
posted on 28/3/07 at 09:18 PM |
I have sealed one with super glue before due to not having anything else to hand.
Sun Tzu, The Art of War
robertst
posted on 28/3/07 at 09:21 PM |
hermatite.... that sounds like the brand of a hemorrhoid ointment
seriously what the heck is hylomar? can't one use a glue of some sort? or even silicone?
Tom
iank
posted on 28/3/07 at 09:45 PM |
http://www.hylomar.co.uk/universalblue.htm
Anonymous
DIY Si
posted on 28/3/07 at 09:51 PM |
Hylomar blue is my favorite sealant. Used in my garage to seal just about anything.
DarrenW
posted on 29/3/07 at 10:39 AM |
JB weld will give you a temporary fix until you can get the new core plugs. You need to decide though if using this will make it harder to remove the
plugs when the time comes.
You will need to drain the system down below the level of the plug if effecting a temp repair and observe the instructions on how to use.
I have had a problem with a core plug rusting from the inside out on an engine that has been stood for a while. Unfortunately the plug is in an
awkward place and means engine removal to change it. JB has stood the test of time for now. A bit of gaffer tape over the top and some gentle heat
(fan heater) helped keep it in place whilst it set.
