mike smith1
| posted on 29/3/07 at 01:43 PM |
1997 919 Fireblade Emissions
Hiya, alongside other Pre - SVA Posts can you tell me the emission values i will have to meet for my 97 919 Fireblade engine, I will hopefully be
using a twin cat system.
Ta Mike
worX
| posted on 29/3/07 at 01:45 PM |
I am sorry that I don't know the answer for your question Mike, but as you already know I have the same engine as you, and mine sailed through
(with a bit of finetuning by Mark) using MAC#1's Single CAT system so you should have no trouble at all!
Steve.
| posted on 29/3/07 at 01:47 PM |
Just checking but have you got a copy of the SVA manual? Mighty useful bed-time reading for the weeks before the SVA test....
mike smith1
| posted on 29/3/07 at 02:03 PM |
Mark could be the man to speak to then, its not the first time i've heard of him being a wizard with the blade engine.
Mike
Steve.
mike smith1
| posted on 29/3/07 at 02:04 PM |
No, have a draft copy, will read that
Mike
bigrich
| posted on 29/3/07 at 02:17 PM |
you will need to meet
less than 0.2% CO at 3000rpm
less than 200ppm HC at 3000rpm
0.97 to 1.03 lambda at 3000 rpm
and less than 0.3% CO at idle
these are current BET test limits whic h i'm 99.9% sure are the same as SVA
they MAY let it use 0.3%co at 3000 and 0.5% at idle
hope this helps
Rich
esn163
| posted on 29/3/07 at 02:34 PM |
Hi Mike
Just to confirm
BET / CAT Test
Fast idle (2500-3000rpm)
CO<=0.3%
HC<=200ppm
Lambda 0.97-1.03
Idle Test (450-1500rpm)
CO<=0.5%
(From Mar '04 SVA manual)
Noise is at 3/4 max power
Mark and Colin at MAC#1 were very helpful when we were trying to get our Blade through.
Have you sent your SVA from off then yet?
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
mike smith1
| posted on 29/3/07 at 02:39 PM |
quote: Originally posted by esn163
Hi Mike
Just to confirm
BET / CAT Test
CO<=0.3%
HC<=200ppm
Lambda 0.97-1.03
CO<=0.5%
Ed
We certainly have, gotta get moving now!
Mike
Does the lambda readings affect a carbed engine or is that just injection?
bigrich
| posted on 29/3/07 at 02:56 PM |
lambda is just a calculation based on chemically correct fuel mixture
so a lambda reading of 1.00 is equal to 14.7 parts air to 1 part fuel . this is where a cat works at its best.
all a lambda senser on an FI engine does is keep the fueling to this level.
you will have to use the mixture screws manually to achieve this level
Rich
