ady8077
posted on 5/4/07 at 07:04 PM |
Etch primer
Hi all
I've just tried using some etch primer on a piece of ally as a test, it went on ok and has dried ok, but its quite easy to scrath off. The paint
is about a year old but both the paint and activator looked ok, does it go bad with age?
Thanks Adrian
matt.c
posted on 5/4/07 at 07:07 PM |
sounds like you havent keyed it up enough?
Try 240 grit or 320 grit paper
ecosse
posted on 5/4/07 at 07:26 PM |
Etch primer should create it's own key on ally, when you were spraying it did you notice it bubble the surface when first sprayed?
Alex
ady8077
posted on 5/4/07 at 07:58 PM |
Hi
I did lightly key the surface, and no I didn't notice any bubbling
Adrian
jambojeef
posted on 5/4/07 at 09:42 PM |
I've had the same thing!
Sprayed my bonnet with brand new etch primer - did sort of notice some bubbling but it doesnt seem to want to stay on anymore than the standard 2k
primer I used on the side panels!
Hmm, maybe our cars will look nice for about the time it takes to drive 10 mins down the road and look like someones taken a shotgun to them....hmmmm!
ecosse
posted on 5/4/07 at 09:53 PM |
If working properly it will cause a small reaction as the acid burns the surface of the ally, which is like bubbling as the paint hits the metal and
then it disappears.
Not sure why it is flaking off again though, did you clean the metal properly before painting?
Alex
