Author: Subject: diff numbers
oadamo
posted on 6/4/07 at 01:16 PM Reply With Quote
diff numbers
hi ive just got a diff the numbers are
(86gg aaa 392)
(4a 1ko1 1344)
anyone have an idea how i could find out what ratio it is or if its an open or lsd
adam
bug1
posted on 6/4/07 at 01:32 PM Reply With Quote
Hi according to my list of numbers an 86gg 4006 aaa 3.92 is alimited slip diff which is 3.92 to 1of a 2.0 doch hope this helps.
Richard
posted on 6/4/07 at 04:44 PM Reply With Quote
ditto above, should be a 392 lsd.
big_wasa
posted on 6/4/07 at 04:51 PM Reply With Quote
yep bet it was from a 2l dohc 4x4 estate
[Edited on 6/4/07 by big_wasa]
oadamo
posted on 6/4/07 at 07:49 PM Reply With Quote
would this be any good the 1/4 mile run i think it will with the lsd. but not sure on the gear ratio thanks
adam
posted on 6/4/07 at 08:03 PM Reply With Quote
depends on engine, gearbox and tune. I would expect it to be fine, all that could go wrong is hitting the limiter in 5th before the quater is up, but thats not likely unless you have a rather large turbo.
oadamo
posted on 6/4/07 at 08:12 PM Reply With Quote
its only an escort rs turbo engine. its runing 210bhp do you think it will suit this engine or is there a better ratio.
adam
oadamo
posted on 6/4/07 at 08:13 PM Reply With Quote
it will be runing a type 9 gearbox
posted on 6/4/07 at 08:32 PM Reply With Quote
im sure there are charts out there to link bhp/tonne figures to rough quater mile times. Id imagine that car would do roughly 10 or 11 seconds and a final speed of maybe 120 to 130. Hence, make sure you are geared to 130. You need the gear calculator program, a search should find it.
edit make that 12 seconds ish.
[Edited on 6/4/07 by JoelP]
