Author: Subject: Brake fluid warning light
Crazy Jay
posted on 25/4/07 at 11:26 AM Reply With Quote
I was wondering if any1 can tell me how to connect the brake warning light up. Is it just a case of connecting the sensor on the brake cap to the battery then to a light? Or is this wishfull thinking? Cheers, Jay
Ketchup
posted on 25/4/07 at 11:32 AM Reply With Quote
pretty much that simple, give the bulb a 12v feed, then use the switch to give it an earth, thats what i did anyway
RazMan
posted on 25/4/07 at 11:34 AM Reply With Quote
You could use your handbrake switch if you have one.
Raz
Crazy Jay
posted on 25/4/07 at 11:41 AM Reply With Quote
Oh brilliant
Wud use the handbrake but i dont have the switch unfortunately. Did I read that it needs a button to test it? If so how wud that work? Cheers again n
Schrodinger
Wire it in parallel with the handbrake switch. IIRC you have to be able to check that the light is working from the drivers seat for sva, ie pull on the hand brake.
zxrlocost
posted on 25/4/07 at 11:42 AM Reply With Quote
hi mate
I used the front brake light switch off the r1 as that has a 12v feed only the 1 wire remember
from memory
1 side of your MC plug goes to earth then the other side to earth on your warning light
positive on your warning light goes to + feed on your r1 loom
then when you press the top of the MC it should light up
youve then got to encorp your handbrake earth into your earth side of the warning light aswell
zxrlocost
posted on 25/4/07 at 11:43 AM Reply With Quote
you really could do with an handbrake switch
Crazy Jay
Oh so u just have to show that the light CAN turn on?
nib1980
Is that the same for me. I have a handbrake switch, but i also have twin metal girling master cylinders. do i need a sensor for each cylinder?
posted on 25/4/07 at 11:44 AM Reply With Quote
Pretty much yes!!! The sensor cap has a float in it attached to the top of the float is a ring of metal- when the float decends (ie low level of fluid left) it completes a circuit between two metal nipples. So it should go battery-sensor-light.
It doesn't matter whether you switch the +ve or -ve.
Crazy Jay
posted on 25/4/07 at 11:45 AM Reply With Quote
Originally posted by zxrlocost
hi mate
from memory
Cheers for all the info fella's, gonna go out and hav a crack at it now. No doubt i'll be in askin more silly questions tho
posted on 25/4/07 at 11:46 AM Reply With Quote
I must learn to type quicker!!! LOL
locoboy
posted on 26/4/07 at 11:15 AM Reply With Quote
Im doing this too at the moment.
Sierra M/c has 3 terminals.
As you look at the terminals 1 - 2 - 3
there is always continuity between 1 and 2 with the cylinder full or empty
There is continuity between 2 and 3 when the button is pressed when the cylinder is full, but not when its pressed when its empty?
and no continuity between 2 and 3 when the cylinder is empty and no button pressed!
Whats going on?
Anyone got a diagram of how to wire this up in conjunction with my handbrake switch?
Locoboy
