Author: Subject: Swirlpot
dave1888
posted on 25/4/07 at 07:51 PM Reply With Quote
Swirlpot
I am looking at going the injection route and one of the items i need is a swirlpot. I found one on ebay but can anyone tell me what the two centre connections are for. I assume the bottom will by for fuel to injectors and the top one for the return. Rescued attachment swirlpot.jpg
paulf
posted on 25/4/07 at 07:54 PM Reply With Quote
Bottom connects to the HP pump , next one up to the low pressure supply pump, one above to the fuel rail return and top one to the tank return to let out any air or vapour.
Paul.
dave1888
posted on 25/4/07 at 08:22 PM Reply With Quote
Where does the low pressure pump fit in. all the drawings i have none of them mention low pressure pumps
ned
posted on 25/4/07 at 08:28 PM Reply With Quote
see:
here
and
here
[Edited on 25/4/07 by ned]
beware, I've got yellow skin
dave1888
posted on 25/4/07 at 08:43 PM Reply With Quote
thanks Ned
dave1888
posted on 28/4/07 at 05:31 PM Reply With Quote
Im confused can anyone tell me or recommend a low pressure fuel pump and a high pressure fuel pump, what pressures do they operate at.
paulf
posted on 28/4/07 at 09:35 PM Reply With Quote
I am using a facet red top pump for the low pressure and a pump from a Sierra XR4 for the high pressure. low presure is only about 2psi and the high presure is regulated to approximately 45psi depending on what injectors and regulator you are using.
Paul.
chriscook
posted on 29/4/07 at 08:41 AM Reply With Quote
If you can get your HP fuel pump below the level of your tank you do not need a LP pump or swirl pot. You can do it like:
tank->filter-> HP Pump-> (HP filter) ->Fuel rail ->pressure regulator -> return to top of tank
If you have two pumps and a swirl pot then you need to make sure that the LP pump has pumped fuel into swirl pot before th HP pump starts.
[Edited on 29/4/07 by chriscook]
Schrodinger
posted on 29/4/07 at 09:48 AM Reply With Quote
That's fine as long as you do not have to lift the fuel out of the tank, very few high pressure pumps like lifting fuel. My Tiger tank had the feed to the pumps in the top of the tank therefore the fuel has to be lifted, some tanks have the feed out of the bottom, then your suggestion is fine.
posted on 29/4/07 at 10:52 AM Reply With Quote
Also the tank should be baffled to help with fuel surge. If the tank has no baffles a swirl pot is probably better
chriscook
posted on 29/4/07 at 11:43 AM Reply With Quote
True - my tank has a pot on the bottom and is baffled. (but I did already say the pump had to be below the tank.)
dave1888
posted on 29/4/07 at 09:41 PM Reply With Quote
So what is the purpose of the low pressure pump. Is it to keep the swirl pot full of fuel and then the high pressure pump pumps fuel from the swirl pot thru the injectors and returns excess to the swirl pot. Sorry if i seem a bit thick but its something i am just having a bit difficulty in processing.
matt_claydon
posted on 30/4/07 at 07:17 AM Reply With Quote
Dave,
Yes, that's exactly right.
stevebubs
posted on 1/5/07 at 08:12 PM Reply With Quote
yep. Spot on
