ayoungman
posted on 19/5/07 at 08:21 PM |
slightly off topic. funny engine noise
Landrover 2 and quater petrol engine. Fairly loud ticking noise when engine under load. Disappears when not or at idle. Whats the cause please.?
[Edited on 19/5/07 by ayoungman]
"just like that !"
Johnmor
posted on 19/5/07 at 08:28 PM |
I'm suprised you can hear anything over the cacofony of a 21/4 Landee engine even when it running sweet.
Sorry!!
If its under load only, could be Big end if there is a rumble,
If it a heavy clicking it could be nearer the top end tappets etc:
omega 24 v6
posted on 19/5/07 at 08:31 PM |
Pinking????????????????
Exhaust manifold cracked/leaking
Dizzy weights
little ends
hughjinjin
posted on 19/5/07 at 09:51 PM |
piston slap
zetec7
posted on 19/5/07 at 09:56 PM |
Worn wrist pin in connecting rod will do that...
http://www.freewebs.com/zetec7/
ayoungman
posted on 19/5/07 at 10:26 PM |
well, its definately not pinking or rocker noise, been there, done that.
what about rings ?
"just like that !"
posted on 19/5/07 at 10:55 PM |
Gudgeon pin or piston slap as suggested probably.
RazMan
posted on 20/5/07 at 06:54 AM |
Is it worse when cold? If so then piston slap is a possibilty. Alternatively it might be small end(s) Don't think rings would make that sort of
noise - does it burn oil?
Raz
posted on 20/5/07 at 07:10 AM |
Pinking would be a rattle rather than a ticking noise . Could possible be the exhaust flange gasket opening up when engine is under load?
posted on 20/5/07 at 01:30 PM |
Exhaust gasket would be my first bet, it sounds just like a mechanical problem when they start leaking.
trogdor
posted on 21/5/07 at 01:29 PM |
would second that, i had the exhaust gasket go on my car and it does sound like a mechanical ticking that gets louder when under load.
