Author: Subject: Types of thinners to use
Simon W
posted on 26/5/07 at 02:58 PM Reply With Quote
I am planning ahead on what type of treatment I am going to give my chassis. I have decided I am going to give it a coat of red oxide primer following by some hardwearing back industrial floor paint. What type of thinners (synthetic, cellulose etc..) should I be using with oxide primer and something like the below?
http://cgi.ebay.co.uk/BRAND-NEW-Johnstones-Black-Floor-Paint-2-5Ltr_W0QQitemZ230131427849QQihZ013QQcategoryZ57220QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Thanks.
Mark Allanson
posted on 26/5/07 at 03:08 PM Reply With Quote
Surely arn't you better using the stuff designed for the job? Try this 300082570707
Simon W
posted on 26/5/07 at 03:22 PM Reply With Quote
Yeh, undecided on the paint at the moment. So what thinners for red oxide primer?
Syd Bridge
posted on 26/5/07 at 05:26 PM Reply With Quote
I use the cheap cellulose 'gunwash' stuff with the red oxide. But Mark would probably give me a slap on the head for doing it!!
( I also use the same stuff for fuel in the grasstracker. 130 octane or thereabouts )
Mark Allanson
posted on 26/5/07 at 06:25 PM Reply With Quote
Slap on head duely applied
Celly thinners will break down the binder, making the paint less durable, I am fairly sure you should use turpentine, but white spirit should be ok
Simon W
posted on 26/5/07 at 07:39 PM Reply With Quote
What ratio?
Mark Allanson
posted on 27/5/07 at 12:56 AM Reply With Quote
How thick is the paint you have bought?
If spraying it (use serious HSE equipment, lead is poisonous!), thin it to about 20secs using a viscosity cup, or to the thickness if single cream is using guessosity job!If brushing it, dont dilute at all, thin it by mixing VERY thoroughly, screwfix do a great electric drill twizzy thing for a few pennies
Simon W
posted on 28/5/07 at 10:14 PM Reply With Quote
Are you referring to the red oxide primer containing lead or my chassis paint? I am just going to be using something like the below for respirator:
http://cgi.ebay.co.uk/Dual-Cartridge-Chemical-Respirator-Dust-Spray-Mask_W0QQitemZ270124778499QQihZ017QQcategoryZ30923QQrdZ1QQcmdZViewItem
If its the primer thats the problem then I will just roller the primer on.
Mark Allanson
posted on 29/5/07 at 07:27 PM Reply With Quote
Roller the lead, spray the chassis black if you need to, the ebay mask is very marginal, designed for dust and LOW toxic vapour, I would use a gloss roller for it all, you will use about 50% less paint
Simon W
posted on 29/5/07 at 09:32 PM Reply With Quote
Thanks for the advice Mark, I will give the mini gloss roller a go!
