Pinto Oil Level
Hi there,
Could someone do me a favour and tell me how far below the top of the hole in the block wherethe dip stick tube goes the oil should be on a 2.0 litre
pinto?
Mine has an after market tube and I am not convinced it is the standard length because I have filled it to the right level on the dip stick and it has
taken a lot less oil thant the manual states. (I have a RS shallow sump with the wing so I believe the oil volume should be the same standard - might
be wrong on this though).
Thanks in advance
Jim
