Author: Subject: VW Polo cooling problems
myeates
posted on 18/6/07 at 05:40 PM Reply With Quote
hi guys my VW polo has just started going wrong at the grand age of 16 with 170000 miles (well got to die sometime) anyway it will keeps on overheatin, but it doesnt do it all the time.
the first thing i see is the temp going up to 110º at which point i turn off, fan not going at this temp but even with the fan switched to go constantly it still over heats, there is no thermostat in it at the moment as i thought that would cure it but it still has problems. its almost as if the rad is not there sometimes as it can be running fine with the fan switching in traffic normally at others.
Mr RAC came out and had a look but said its fine as it wasnt overheating at that point and the head gasket is fine(think he thought i was crazy).
my second thought was that the water pump isnt working sometimes could this be the problem, there is no leaks anywhere.
sorry about my ramblings just wondering what is causing the intermitent problems.
any help greatfully received
regards
Mark
[Edited on 18/6/07 by myeates]
bigrich
posted on 18/6/07 at 05:45 PM Reply With Quote
i seem to remember from my dim and distant past the same problem on a polo we had in and the water pump impeller had parted from the shaft and was'nt circulating coolant causing it to overheat and have a lukewarm heater
posted on 18/6/07 at 06:03 PM Reply With Quote
Water pump impellers coming off is a common problem with polos. One clue is even when its overheating the heater will only blow cool air . Make sure you fit a new thermostat at the same time. Fan not working could be?? because coolant is not circulating
Humbug
posted on 18/6/07 at 06:12 PM Reply With Quote
You could try turning things ar$e about face and going for a Locost rad
myeates
posted on 18/6/07 at 08:25 PM Reply With Quote
bingo thanks guys at least you both said a similar thing will get new pump see if it sorts problem, hope so the cars got to last till locost is on road then itcan die but not yet.
that is exactly what is happening i was sat in car while it was getting very hot with my hand over the vent saying this isnt 100 degree air then thinking the gauge was wrong till it actually did get wet.
thanks very much
big_wasa
posted on 18/6/07 at 08:37 PM Reply With Quote
I had one where the stat would stick
myeates
posted on 18/6/07 at 08:39 PM Reply With Quote
no stat fitted, i took out to see it would fix it but didnt looks like water pump tho
Danozeman
posted on 18/6/07 at 08:44 PM Reply With Quote
Sounds like water pump to me.. The impellors often come of Vw's.
Dan
posted on 18/6/07 at 08:57 PM Reply With Quote
Better than a Mk4 Golf - apparently the flywheel has been known to un-rivet itself from the crankshaft...
myeates
posted on 23/6/07 at 09:22 PM Reply With Quote
just got my water pump off to change (will be putting new one on anyway) and guess what? water pump looks ok the impeller is still intact is there anything else it could be or could the impeller just be on its way out as the problem was intermitent
thanks again
myeates
posted on 23/6/07 at 09:24 PM Reply With Quote
thanks again
posted on 24/6/07 at 08:11 AM Reply With Quote
The impeller is probably intact but spinning on the shaft . For some strange reason it can be an intermittant problem
myeates
posted on 24/6/07 at 08:24 AM Reply With Quote
ok did try to turn the impeller on shaft and couldne move it suppose it could be the heat
