RK
| posted on 24/6/07 at 08:18 PM |
Any Deman SR7 Builders?
I would like to apologise for bothering people on here, but I cannot get on the US site, and the frame builder has not put me in touch with other
builders.
I have a problem. The width of the mounting holes on the MX5 diff carrier are 23" inside of the holes. The OUTSIDE width on the frame is
23". This is a potentially big problem: it looks like the mounting would work wonderfully if it went right through the square tubing!
Also, I have a handbrake from a Celica, which appears to be quite different than that of the MX5. I can tell where to mount the handle, but not where
to put the cable(s). There is no detailed build manual with this kit.
Before I start riveting panels etc, I need to make sure what I have will work.
[Edited on 24/6/07 by RK]
Fozzie
| posted on 24/6/07 at 09:10 PM |
RK, I believe 'zetec7' is over in Canada.
It may be worth U2U'ing him, to see if he knows of other Deman builders who may be able to advise?
ATB Fozzie
RK
| posted on 25/6/07 at 12:24 AM |
Thanks. I tried, but he didn't respond.
RK
| posted on 25/6/07 at 01:22 AM |
OK, I found a pic that explains it.
http://www.imagestation.com/album/pictures.html?id=2091686761 scroll down to pic 51
It seems the bushings inside the diff carrier are removed and the discs with the offset holes go over the opening (one on top, one on bottom). This
way the carrier aligns with the frame for maximum strength when there is upward pressure (as in going over a bump). It might not make any sense to
anyone else, but I got it and that's what counts now!!!
Thank you everyone. I will gladly discuss anything to do with an MX5 build if anybody needs any advice from a total idiot with cars.
Fozzie
| posted on 25/6/07 at 08:27 AM |
Rk, I am glad you found the answer to your question!
I have found another Canadian Locoster in Canada, Vancouver IIRC.
He is building a Deman sr7, but Busa (bec) powered.....
His name on here is BusaLoco, but he hasn't been on here since the end of May.....
But may be worth a 'search' or see if he has an email, just in case.
He also has pictures of his build in his Photo Archive........
ATB Fozzie
C10CoryM
| posted on 25/6/07 at 04:06 PM |
busaloco seems to have dissapeared around the time his car should have been done. I emailed him a while back with no response. Hopefully he is busy
out enjoying his car.....
Always makes me wonder when a guy stops posting soon after finishing a car which might be faster than anything else he has driven
"Our watchword evermore shall be: The Maple Leaf Forever!"
RK
| posted on 25/6/07 at 08:35 PM |
Yeah, once done, they lose interest in the net. Can't blame him. Anybody got a couple of MX5 cables with housing kicking around before I order a
second hand one or two from Colorado??
Where in the Lower Mainland are you? I'll be there to visit the family etc (and get depressed about the housing prices) in about 3 weeks.
[Edited on 25/6/07 by RK]
madman280
| posted on 26/6/07 at 11:59 PM |
Why don't you just give Dan at Deman a call. He's a sharp guy who's usually willing to help out and get his cars finished. I think
he may even have a web site just for people who are building his cars.
CJ
[Edited on 27/6/07 by madman280]
RK
| posted on 27/6/07 at 12:54 AM |
Because he's on his boat this week incommunicado. I would like to make a bit of headway before leaving for holidays myself.
C10CoryM
| posted on 27/6/07 at 01:42 AM |
I was thinking a little more along the lines of someone getting on the gas in their new car and losing it . Suddenly person X no longer posts, or
responds anymore. Hopefully not though.
Im in White Rock, which is exactly where you want to avoid if high house prices upset you.
Cheers.
RK
| posted on 27/6/07 at 01:52 AM |
Are you kidding? I spent 10 years at Broadway and Granville, 49th and East Boulevard before that, and West Van before that. White Rock is dirt cheap -
further than I want to be from N Van mountatins, but admittedly a lot closer than I am now.
As far as my build goes, I have painted my frame and wishbones (and pedals), and need further instructions on where to start. I cannot email any other
SR7 builders, because I don't have their addresses. Right now, I'm getting as high as Dee Dee Ramone on paint and thinner fumes.
