Author: Subject: Raceleda Sierra Uprights Torque settings
clockwork
posted on 26/6/07 at 11:36 AM Reply With Quote
As it says really. I got these without instructions, any-one got a set they could scan for me? Also torque settings, and do I need threadlock?
Can someone recommend a caliper/disk setup they are happy with too. I'm looking at running 13, 14 or 15 inch wheels, bike engine.
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
fesycresy
posted on 26/6/07 at 04:19 PM Reply With Quote
Haven't got the torque settings but with the brakes I'd go Wilwood with a solid or cross drilled / grooved disc.
My vented 260mm discs take some heating up even with Wilwoods - they need some vigorous driving to get them to temp
Lyn.
clockwork
posted on 28/6/07 at 07:55 AM Reply With Quote
I was thinking of solid disks.
Also, bump
clockwork
posted on 1/7/07 at 05:04 PM Reply With Quote
bump to the top.
[Edited on 19/7/07 by clockwork]
clockwork
posted on 19/7/07 at 01:14 PM Reply With Quote
Bump. Someone has to know surely !!
procomp
posted on 19/7/07 at 01:18 PM Reply With Quote
Hi MNR should have all info re raceleda products.
cheers matt
scotmac
posted on 21/7/07 at 03:05 PM Reply With Quote
MNR informed me that all the raceleda stuff should be torqued to cortina specs, since that is what they were designed for.
Specifically:
caliper bolts: 58n/m
disc bolts: 42n/m
caliper mount plate bolts: 30n/m
hub bolts: 42n/m
scotmac
posted on 21/7/07 at 03:10 PM Reply With Quote
Oh, and here is a thread on how to torque up the hub:
http://www.locostbuilders.co.uk/viewthread.php?fid=3&tid=6826
scotmac
posted on 21/7/07 at 03:11 PM Reply With Quote
Oh, and i used loctite...figured it couldn't hurt.
clockwork
posted on 23/7/07 at 01:10 PM Reply With Quote
Cheers.
Scotmac what discs/calipers are you using?
Also, in my search I found the cortina stripdown in
http://gtslocost.locostsites.co.uk/downloads.htm
scotmac
posted on 6/8/07 at 11:20 PM Reply With Quote
Originally posted by clockwork
Cheers.
I am using the raceleda calipers and discs that came in my "raceleda sierra replacement front end kit" from mnr. I believe the calipers are rebranded "outlaws" (lightweight aluminum r16 replacements).
The discs are non vented, which is good (i have seen quoted that venting is overkill for these cars); and they are cross drilled and slotted, which is not soo good (does very little good, and makes the discs more likely to crack).
Did you get yours installed?
Cheers, -Scot
