Author: Subject: Where to get 8mm-10mm fuel hose joiner
rayroni
posted on 19/7/07 at 07:12 AM Reply With Quote
Could do with one today, anybody got any suggestions where to get one from - 'cause I somehow think halfrauds won't stock them. Is it the type of thing you can get from a motor factors?
marshall
posted on 19/7/07 at 07:39 AM Reply With Quote
burtons motor sport do them in brass
hope this helps....
skippad
I bought one yesterday from my local motorfactors, always have bits in stock, more helpful/userfriendly than Halfords and cost about 20p.
Skip
ditchlewis
posted on 19/7/07 at 09:27 AM Reply With Quote
car builder solutions have them.
ditch
omega 24 v6
posted on 19/7/07 at 11:28 AM Reply With Quote
10mm microbore with 8mm microbore slid inside and a ring of solder around to seal. Just a guess this one but I THINK the 8mm will go into the 10. Someone maybe able to confirm this I hope as it's what I've got in mind for my fuel pipes.
craig1410
posted on 19/7/07 at 12:14 PM Reply With Quote
If you do this then make sure you flare the ends of the pipes slightly to positively retain the pipe when clamped.
I got my 10mm to 8mm reducer from Vehicle Wiring Products.
Craig.
omega 24 v6
posted on 20/7/07 at 03:52 PM Reply With Quote
Nah I did'nt like the idea of a sharp flared edge so I got a piece of copper wire and wound it round the pipe and run a ring of soldered round it as well. Job's a good un as they say. You're right though about needing some sort of retaing mechanism.
craig1410
posted on 20/7/07 at 08:40 PM Reply With Quote
I didn't have a sharp flared edge, I used a brake flaring tool and just gave it maybe 25% of a full flare to leave a nice tidy rounded bulge on the end of the pipe.
I have used the other method of soldering on a compression olive. These are usually available for all the standard sizes of copper pipe including 8mm and 10mm microbore.
Craig.
