Author: Subject: Sevens and A frames
NigeEss
posted on 19/7/07 at 11:00 PM Reply With Quote
Sevens and A frames
Has any one used an A frame to tow thier Locost ? Wondering if it's a viable alternative
to a trailer.
I know there are legal issues over A frames due to unbraked trailer blah blah, but a BEC
behind a decent sized car should be within limits.
So, has anyone done it ?
If so, did you have some sort of permanent fixing points on the wishbones ?
Also, is there any issues with LSDs when towed long distances similar to autos ?
robertwa
posted on 20/7/07 at 02:16 AM Reply With Quote
I would have thought a BEC would cause damage to the gearbox unless you had the engine idling and in neutral?
rayward
posted on 20/7/07 at 05:15 AM Reply With Quote
its not the unbraked trailer thats the problem, they are only legal for recovery,
Ray
Danozeman
posted on 20/7/07 at 05:58 AM Reply With Quote
Towing most rwd cars long distance will cause problems if the prop shafts on.
The oil in the box doesnt circulate properly because the main shaft isnt spinning.
Dan
NigeEss
posted on 20/7/07 at 07:04 AM Reply With Quote
Ray
So how do the camper van boys get round the law, or don't they ???
Spyderman
posted on 20/7/07 at 02:53 PM Reply With Quote
Towing a car on an A-frame is not illegal as long as both vehicles are legal. It is just like a four wheel trailer.
You don't want fixing onto your wishbones. Fix to the chassis near to the wishbones if possible.
Spyderman
kitcarcollection
posted on 29/4/08 at 07:43 AM Reply With Quote
anyone experience towing bike engined kitcars with an a-frame for larger distances? Would it be better to let the engine run idle during towing or would the gears / bearings take suffiient "spalsh" oil anyway?
[Edited on 29/4/08 by kitcarcollection]
Dutch kitcarcollection.
