FastBarney
posted on 12/8/07 at 12:53 PM |
fuelpump for webers
hey
i just bought a set af webers that i going to put on my 1600 pinto engine
now i having a question about the fuelpump that i need.
I Going to buy a facet one
witch one is the best for fueling my webers a interrupter electric pump or solid stated electric pump? What is the difference anyway?
Together with that i tought of using a king fuel regulator.
or is that not necessary if you are using a solidstate one, because the give around 3.5 -4 psi. And thats what webers need for pressure (4 psi).
cheers
melvin
posted on 12/8/07 at 01:01 PM |
Any of these should be OK.
Pinto mechanical pump
Facett/Bendix Solid State Pump
Burlen-SU Pump (MGB size or Jag)
AC Electric pump from 1980s Rover 216S (pre hatchback 1600cc with SU carb ).
blakep82
posted on 12/8/07 at 02:01 PM |
that what i'm wondering too
________________________
FastBarney
posted on 13/8/07 at 03:59 PM |
So if i use Facett Solid State Pump
i don't need a pressure regulator? right?
regards
melvin
posted on 13/8/07 at 08:30 PM |
regards
melvin
If it the "standard" road version no but to qualify this a bit the little solid state pump also comes in different versions.
see http://www.completeautomobilist.com/parts/fuel+system/
