Author: Subject: is Silicone Hose flexible?
saigonij
posted on 12/8/07 at 04:46 PM Reply With Quote
the water rail on my zetec, is not in direct line-of-sight to the radiator inlet, needs to have a bit of a bend in it.
therefore i was thinking about silicon hose....
but i dont know how bendy it is???
anyone tell me what its like?
balidey
posted on 12/8/07 at 04:48 PM Reply With Quote
Yes it bends, but it will kink very easily and may close up. Best bet may be to use a shallow 135 degree bend. Or a bent alloy section of pipe
AlphaX
posted on 12/8/07 at 04:57 PM Reply With Quote
45 degree bend would that be. A 135 degree is a sharp bend.
saigonij
posted on 12/8/07 at 05:08 PM Reply With Quote
here is a simular example, expect my bend will need to be shallower as my rad is not as wide...
will i be able to put this sort of bend in the pipe?
[img][/img]
cadebytiger
posted on 12/8/07 at 05:16 PM Reply With Quote
if you get the superflex stuff you should be ok. the other stuff is not very bendy at all unless you get it in small diameters
http://www.rallydesign.co.uk/catalog/index.php?cPath=147_558_1330
balidey
posted on 12/8/07 at 07:30 PM Reply With Quote
Not necessarily, i have seen both obtuse and acute bends refered to as both 45 and 135 degrees.
But thats not important, as the OP knows what angle is needed.
trextr7monkey
posted on 12/8/07 at 07:47 PM Reply With Quote
Revotec make some excellent stuff with spiral reinforcement which would do you no harm to fit, we looked at it down at one of the shows it will make a U bend without kinking but is -err... slightly more expensive than the ordianary stuff.
thunderace
posted on 12/8/07 at 09:56 PM Reply With Quote
SILICON HOSE WIRE REINFORCED SUPERFLEX
ebay
Item number: 290119899368
posted on 13/8/07 at 04:41 PM Reply With Quote
45 degrees is a very sharp bend. 180 degrees is a straight pipe!
saigonij
posted on 13/8/07 at 05:25 PM Reply With Quote
so anyway.... getting back to my original question...
would a straight piece of silicon hose be able to bend in the manor illustrated in the picture i attached?
cadebytiger
posted on 13/8/07 at 07:22 PM Reply With Quote
highly unlikely but as i said the superflex hose would :p
link as above
posted on 13/8/07 at 07:59 PM Reply With Quote
It would almost certainly kink. Either use two bends linked by an alloy pipe, or get the "ribbed" variety that has a coil spring built in to stop it kinking.
saigonij
posted on 13/8/07 at 08:13 PM Reply With Quote
cheers ears fellas...
i was gonna use silicon hose all round, but i think ill stick to normal hose from Car Builder Solutions.
posted on 13/8/07 at 08:23 PM Reply With Quote
For that sort of bend find a road car with hose of roughly the right shape. And get either the OEM style rubber hose or the Silicone equivalent.
posted on 13/8/07 at 08:24 PM Reply With Quote
adithorp
posted on 16/8/07 at 09:37 AM Reply With Quote
This is new from Gates
http://www.gates-unicoil.com/
Adrian
