Arthur Tizard
posted on 13/8/07 at 11:55 AM |
locost v8 exhaust?????
can some one tell me if they know how/where i can get a locost v8 exhaust???
it also needs to look the part!!!
Many thanks
Arthur
froggy
posted on 13/8/07 at 05:52 PM |
anything under 1k is good value for a stainless system ,if you can find some centre outlet cast manifolds you can run a single pipe through the side
panels to your silencers but these manifolds are fairly restrictive
DanP
posted on 13/8/07 at 07:38 PM |
If you can't stomach spending a thousand quid or more on a set then why not try making a set? Several people on here have, heres my attempt:
Having made a set I do now see that it does take a while and thats why they cost so much tho!!
And a bit a diary about how I did it (Still very much a work in progress website)
http://members.lycos.co.uk/dtep100/v8viento/exhaust.html
Tip: Don't muck about with a dremel like I did on the first side - just use a bench grinder and a flap wheel - still get a nice finish and much
faster.
