oadamo
posted on 16/8/07 at 02:23 PM |
sierra rear brakes
hi i read a while ago that you can use golf rear calipers because there alloy but do you no what car there off is it a gti. because ive looked on the
scrap yard and there all drum thanks
adam
ERP
posted on 16/8/07 at 02:45 PM |
I'm using Mk4 golf calipers, which are alloy, and I believe are identical to most of the VW/Audi parts in that year range.
I'm using cosworth rear running gear and the caliper carriers on the Golf units leave the pistons about 10 mm further out (radially) than I
would like on the standard rear discs. I haven't decided if I'm going to make up brackets to deal with this, or buy Focus RS rear discs
and have them turned down. I might also be able to get away with them as is.
They may be a better fit on standard Sierra rear parts, I don't have any to test.
[Edited on 16/8/07 by ERP]
